Quarantine Garage Sale
Quarantine Garage Clean Out
I have many parts that I don't need. Mainly OEM but some aftermarket. Located in Houston, TX. Local sale preferred. But I will ship at buyers expense. I will only ship items that are not too heavy/not large in size. Add shipping cost to prices on list. I can also send pics of individual items if requested in PM. Forms of payment - Paypal so add the fees. I do take Zelle and Venmo as well. *Brake Calipers* PAIRS Pair of front s13 Calipers - $old Pair of rear s13 Calipers (Red) - $old Pair of rear s13 Calipers (Black)- $40 Pair of rear s14 Calipers (Surface Rust)- $old *Rotors* PAIRS 4 lug rear Brand New - $30 4 lug rear used - $20 4 lug front used - $20 5 lug front slotted for oem calipers - $35 5 lug z32 rear used - $20 5 lug 30mm z32 fronts - $20 5 lug 30mm z32 fronts - $20 *Dust Shields* 1 front - $5 Rear pairs - $10 *Diff Covers* z32 cover - $old s14 cover - $old S14 Driver Axle no rips good thread - $old Unknown driveshaft pieces - $20 each S14 PBM Front Coilovers, no leaks, shocks are not loose, adjustable top hats, nut on top of shock has some surface rust - $280 NEW PRICE *Adjustable Arms* All threads & nuts good s13 rear black Toe SPC - $60 pair s13 rear Toe ISR - $60 pair JDM Gold front tension - $old *Knuckles* s13 front knuckles w/shields - $50 pair s13 front knuckles - $old s13 front knuckles - $old s13 rear knuckles - $30 pair s14 rear knuckles - $old z32 aluminum rear knuckles w/ ball joint cones- $30 pair *Power steering Reservoirs* s13 res w/cap and lines - $25 s14 res w/no cap and lines - $25 *OEM ARMS* PAIRS s13 rear LCA w/ bad balljoints - $30 z32 rear LCA w/ bad balljoints - $old s13 rear camber arms - $20 s14 rear camber arms - $20 s13 rear toe arms - $20 s14 rear toe arms (Sandblasted) - $20 s14 rear toe arms (OEM Black) - $20 s13 rear traction arms - $20 z32 rear traction arms (Reinforced) - $20 s13 ka24de Intake Pipe no rips OEM - $25 manual driveshaft (48 3/4 ish length) - $old s13 and s14 bulb holders - $5 each s13 pass. side power window switch (button not broken) - $60 s13 cracked pass. side tail light - $5 s13 pass. side tail light - $15 s13 Center light (Edge chipped) - $5 s14 bumper lights orange non broken - $20 pair random small light with pigtail - $5 s14 trunk rubbers - $10 (Bag) s14 Firewall rubbers - $10 (Bag) *Electronic Boxes* ALL Unknown if working S13 Driver Window Amp - $old S13 Timer controls - $10 each (2) s13 Wiper Amp - $5 S13 Door Lock Timer w/pigtail - $10 s14 Airbag Box - $10 s13 seat belt module - $5 s13 auto trans module - $5 Other stuff you see - $5 each s14 gas door release - $10 Ignition Coil Igniters - $5 each ISR/ISIS fuel adapter - $5 s14 dome light - $10 S13 Hood Hinges - $old S14 Hood Hinges - $old S14 Hood Release Cable - $old S14 Passenger Door Panel Minty no holes no cracks - $old *Seat Belts* Unknown Condition Brown with L shape Bracket - $old Black with white plastic - $15 pair (3 Pairs) black belt covers - $5 (3 Available) s13 lower steering column plastic no damage - $10 s14 Cluster Surround - $20 No damage w/ buttons (2 Available) s14 wiper switches - $old s13 Manual books and leather cover water/dried up - $10 all 3 drift ebrake button ($5) small ac vents - $10 pair non broken Single dash small vent piece - $10 non broken Buttons - $5 each (Unknown Working Condition) s14 washer fluid res tank - $old Privacy Covers - $10 s14 Quarter Glass - $30 each or $40 both s14 rear 5 lug hubs - $120 Pair z32 rear 5 lug hubs - $120 Pair Last edited by rabbitph; 02-08-2021 at 10:32 PM.. |
Sold all of below:
S14 diff cover S13 front brakes 2 pairs of s13 rear brakes Front dust shield 1 pair of rear dust shields Jdm tension arms Both s13 front knuckles w/o shields S14 rear knuckles S13 driver window amp Isr fuel adapter S14 passenger door panel Hazard button S14 washer reservoir |
