rb25 reverse lights Wireing help needed.
I know I need to wire into the reverse ligh sensor on the trans but Im not sure which one it is and what I need to wire to it. If anyone has pics or info on this I would much appreceiate it. Thanks in advance
anyone. Ive been researching and cant find shit about it. I do know which sensor on the trans in the reverse sensor but I dont know where on the s13 to wire into to get them to work
I've been searching for this answer as well...I'll let you know if I come up with anything this weekend when we try to wire mine up...worst case, we may just hardwire in a switch to just turn them on like headlights...
I punch b*tches for gold nuggets... |
so where do you hook it up too. Ive read their are wires near the fuse block on the passenger side strut tower that you need to tap into but its seems if the stock plug for the ka trans is still hanging under the car you could just hook into that and then into the rb sensor. It seems like it should be easy but its not.
