#181 |
![]() Join Date: Mar 2009
I've been contemplating this lately with having the Z33 trans in two of my S13's. I'm thinking of having a fabricator friend make me a removable/replaceable steel skid plate that bolts to the frame rails, spanning across them and just over the transmission. Yeah you use a little more ground clearance, but then you can just boardslide across that thing all day long and not hurt the trans, and then replace it off of a template when the time comes.
Something like welded nuts in the rails, and counter sunk screws into the plate. I used to be against skid plates when my car was super slammed, because there wasn't any room between the street and the bottom of the car for a skid plate lol. But after ripping the oil pan off an engine and raising the car a bit, it's definitely a more appealing option than breaking the car. Last edited by TheRealSy90; 02-26-2018 at 05:02 PM.. |
#183 |
My roommates project. He took my KA and refreshed it. He really wants to LSx swap it but in the mean time this will do. Body/Paint first then go back and swap it.
![]() It almost done. I have only one fan running since these draw so many amps. need another relay for the second fan. It is also breaking up underboost at times, i think i need to play with the plug gap. I have bkr7e's in there but I cant remember what i gapped them too. ![]() ![]()
#185 |
![]() Join Date: Oct 2013
I ran 2 seperate relays for my fans with seperate 10G wires to power each one, and that solved a shit load of issues for me. Although my fans flow like 3600CFM, so when the fans come on at a red light or something the car drops like 500rpm for a second, lmao.
Also, after inspecting plug gap (I run mine at .028 on my KA with LS coils) you might want to inspect the coils for a weak one or just swap to LS coils. The JZ coils are known for going to trash in their age. |
#186 | |
#190 |
Its been a minute, just minor changes to suspension. Villans angle kit, gk tech sway bars. Starting to really learn the car, its a super fun and reliable set up
#193 |
Thanks dudes, just added an Xcessive skid plate last night. It bolts right up since my oil pan was pretty smushed in... already replaced it once. Next up is subframe bushings
#194 |
![]() Join Date: Apr 2019
Very cool build. Love those Volks and thinking about a set for my vert.. hmm... But I am suuuch a fan of white wheels! We all have our own style though. I like the red paint as well. Can't believe the neighbor backed into it either oof. Big oof! That GT28 looks niiiice doe
