Guest
Posts: n/a
<a href="http://www.livegem.net/camppain/pics2.htm
you'll" target="_blank">http://www.livegem.net/camppain/pics2.htm you'll</a> find pics of my car's and some pics of my recent clutch install. all thats left is setting the t/o bearing properly and bolting the trans case and drive shaft and my 240's operational again! i will be able to test out my struts n springs! |
Guest
Posts: n/a
and the techs @ work told me it would be hard without a lift!
bahhhhhhhh thank god i got a crappy sohc no need to move the muffler |
Guest
Posts: n/a
its a satock oem replacement. i spent all my $$$$$ on struts springs and bunch o stuff from pdm
Guest
Posts: n/a
that one looks so different from the stock...... jeez...... the stock one must take a real beating
Guest
Posts: n/a
actually the kid it was aquired from said it was a centerforce clutch. i have no idea how the f**k that happened. i rarely beaty the car to make anything look like that. i dunno.
Guest
Posts: n/a
woooo hoooooo i got the trans in all i need to do is bolt it down and put the starter in add fluid and a few misc other things and im done!
silvia will be back! muh hua hua ha ha ha |
Guest
Posts: n/a
OHHHHH WEEEEEEEEEE
i just finished everything (mostly everything). i reversed and drove it back up in my garage its alive!!!!!!!!!!!! woooooo hooooooooo i love what you do for me tooyooo......wait err nissan! all i gotta do is put on last bolt in for the trans @ work, bolt the cat back up cause i was lookin inside of it, and make sure everything is tightened. other than that im back baby! |
