![]() Join Date: Apr 2008
Clicking Noise and Idle Problem
Hey guys,
I had a clicking noise that seemed to be coming from behind the dash when the Fans for the AC were on with any of the settings except for the setting that blows air both at the feet and straight ahead. I had also had an idle problem that I had looked into and figured that it was just the coolant sensor. I replaced it and the clicking went away, but now its just making a quieter noise behind the dash. Is it possibly a relay or fuse that needs to be replaced. I am still having a bit of an Idle issue too. I am thinking maybe its the o2 sensor or something. Any help would be greatly appreciated. Thanks
![]() Join Date: Apr 2010
you're not in boost at idle, so my thoughts would be no.
My friend's swapped 95 does the same clicking. He never really cared to fix it so he just leaves the fan on the feet/vent setting. If you figure out what's causing it, that would be kinda cool. |
