i need help, I'm having problems with my car its a s13 with a sr20det i had it for 2yrs with the SR and today when i was taking off the car starts reving but the car is burly moving i don't know if its the turbo or the clutch, when it picks up speed it pulls but my boost goes to 8psi and then it starts going down on full throttle and also when the car is @ 3000 rpm and i punch it the car stars vibrating and i here like a squealing noise so i think it the turbo but not sure some help would be appreciated
THANK YOU IN ADVANCED
![]() Join Date: Sep 2005
if you are driving and you put your foot to the floor and you just rev like its in nuetral. Look at your clutch.
If you can still drive fine, but you are not boosting. Check the turbo. Look in your IC pipes for oil
well i have a blitz BOV and at the end it has oil stains around the lip
