![]() Join Date: Oct 2018
Oil Catch Can sizes
Hey Guys,
So I'm looking at catch cans for my Ka24de. The PCV valve on the block is 9mm hose, but most fitting on catch cans I see is 15mm. What do you guys do to get around that? I figured I could just change the fittings, but most of these manufacturers don't list what the fitting sizes are. Thanks for your help! |
![]() Join Date: Oct 2013
I switched mine to -8AN (Which is 1/2 hose if you're not familiar)
I tapped the valve cover to 3/8NPT and ran a 90* 3/8NPT to -8AN fitting, and on the PCV I believe its already 3/8NPT, so just used another adapter fitting. My catch can is a vented can from www.racecatchcan.com , if you get in touch with them, they'll make about anything you want. |
#3 | |
I did not. I don't see a reason too. Start the car and put your hand over that line and tell me if you think its possible for something to get sucked back in. That thing moves some air.
Considering mine is hooked to a vented can (which we will call it sealed, as nothing is technically exposed to the elements) nothing that could harm the engine could get in it anyways. |
| 9mm to 15mm, catch can, ka24de |
