Old 05-13-2011, 05:34 PM   #1
240driftr
240driftr's Avatar
240driftr is an unknown quantity at this point
Exclamation Sr maf problem
Ok so I know this is going to sound like a wiring problem but I'm pretty sure it's not. Wen I bought my motor it didn't have a Maf so I used a g20 sr maf. Was working fine but wud cut out very rarely. On my way to Connecticut it sided bit started workin again. Than died at my friends up there. Bought a ka single cam Maf was workin good but than on the way home it started cuttin out wen I only made right turns. Now it died today afer tryin to leave work. I'm gettin another sr maf. So can some pls shed some light on this problem lol. Thnx for your help in advance.
240driftr is offline   Reply With Quote
Old 05-13-2011, 07:20 PM   #2
Sileighty_85
Sileighty_85's Avatar
check ECU for codes
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-13-2011, 07:40 PM   #3
240driftr
240driftr's Avatar
Will do. Thank u
Old 05-14-2011, 01:46 PM   #4
240driftr
240driftr's Avatar
Ok so I checked my ecu for code an the red led bulb just stays lite up and doesn't blink. What does this mean?
Old 05-14-2011, 02:04 PM   #5
chituntang
chituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nice
Did you use a screw driver to turn the little plastic thing inside? But if your car is cutting out only making a right turn, then it is most likely wiring problem.
chituntang is offline   Reply With Quote
Old 05-14-2011, 02:18 PM   #6
240driftr
240driftr's Avatar
Ok. Check the ecu an first got a 12 and than a 34. Than started to car an did it again an I got a 55 which means no problems lol wtf
Old 05-14-2011, 02:24 PM   #7
240driftr
240driftr's Avatar
i know a 12 is air flow circuit an 34is a knock sensor
Old 05-14-2011, 02:32 PM   #8
240driftr
240driftr's Avatar
im going to rip apart my hole wiring harness now an see if somethin is messed up. thanks for the ecu advice. ill let yous know what happens when im done. please feel free to share more opinions if you have any.
Old 05-18-2011, 06:30 AM   #9
240driftr
240driftr's Avatar
Ok so I checked all my wiring an just decided to put gold plated connectors in an I tetras the ecu. At first it popped up with a maf an a knock sensor code again an after I shut it off an reread it again it only had a knock sensor code. I cleared the ecu so far an I haven't checked it yet. Thank you for both of your advice
