12065729_891860750848990_2744030617224422321_n.jpgPrice 21k obo Pictures can be found at http://s947.photobucket.com/user/tru...?sort=3&page=1 Stickers have been removed Price is "or best offer" ALL offers are considered. This is a perfectly working and ready to race machine, this is ideal for someone wanting to get into a racing/time attack series for pennies on the dollar. The Car was built following the nasa rule book to run in HPDE, TT, and Global Time Attack unlimited rwd. Cage is FD Legal as well, can easily be converted into drift car Here are the specs: Chassis: 1997 Nissan 240sx SE Horsepower/Torque: It was detuned to 450 to run pump gas old hp was 606rwhp @8000RPM 466rwtq @6446RPM @ 22psi (want more power? Just turn up the boost! We felt 600 was balanced) Weight: 3030lbs With driver and Full Tank Engine: R32 rb26dett Jun crank collar Tomei oil restrictor Tomei oil pan baffle Greddy oil pump Greddy clear timing belt cover Greddy intake manifold HKS 272 in/ex cams HKS adjustible cam gears HKS timing belt HKS fuel rail Wiseco 86.5mm pistons Eagle H beam rods Cometic head gasket ACL Race rod bearings ACL Race main bearings ARP head studs ARP main studs Twin Garrett gt2871r-10's TSI Ported OEM exhaust manifolds TSI Ported ITB runners TSI -3an SS braided turbo oil and water lines TSI Divided OEM twin turbo pipe TSI Ported and polished head TSI Custom intake pipes TSI -6an SS braided power steering lines and power steering cooler TSI -10an SS braided oil filter relocation kit and oil cooler kit using Greddy thermostatic filter relocator ATI race crank damper and water pump pulley Dual synapse blow off valves Aem air filters Mckinney Motorsports touge downpipe Mckinney Motorsports fmic kit NGK bkr7e spark plugs Isis Performance blast pipe exhaust with 4" tips FabWorks custom oil catch can FabWorks -AN valve cover adaptors Cooling: Koyo aluminum radiator Flex-a-lite 340 series dual electric pusher fans Raw Brokerage radiator hoses N1 OEM water pump Nismo thermostat NRG radiator diversion panel DIF PWM fan controller Fuel: Injector Dynamics ID1000 injectors walbro 385 fuel pump Aeromotive FPR Powerhouse Racing billet fuel hat TSI fuel pump direct-wire relay kit TSI -8an feed lines with inline fuel filter & -6an return lines Drivetrain: Rb25det transmission Spec Super Twin clutch Isis Performance Short shifter Mckinney Motorsports engine and transmission mounts with solid isolators Driveshaft Shop 4.5" aluminum "1000hp" driveshaft S15 helical differential Suspension: Fortune Auto 510 Series coilovers with Swift Springs upgrade 12k front /10k rear Fortune Auto tension rods Fortune Auto ruca’s Fortune Auto traction arms Fortune Auto toe arms Stance solid Subframe bushings Stance solid Differential bushings SPL Eccentric lockout kit Sikky 32mm front sway bar Oem rear sway bar Brakes: Z32 front calipers Z32 rear calipers Z32 rear e-brake assembly R33 e-brake cables Carbotech xp20 front pads Carbotech xp10 rear pads Powerslot rotors Exterior: Shine Auto front bumper Shine Auto side skirts Shine Auto rear valences Shine Auto carbon fiber rear diffuser OEM JDM s14 kouki rear bumper OEM 180sx type-x turn signals B-Magic 30mm front fenders widened even more Origin type2 50mm rear over fenders Seibon vented carbon fiber hood Kognition chassis mount 72" wing Euro spec oem kouki headlights Sonar l.e.d. tail lights Nagisa Auto GT front tow hook TSI Custom Rear tow hook Interior: Sparco eve seat less then one year old passenger is old junk seat Nrg short hub Nrg 2.5 quick release Nardi 360mm deep corn steering wheel Nismo Shift Knob Battery relocation kit Firecharger dual nozzle fire suppression system Rjs racing harness Rjs racing window net Custom 8point D.O.M. rollcage with "Nascar" door bars Electronics: AEM v2 ems Racepak iq3 digital dash with AEM interface Dual AEM uego wideband gauges AEM serial datastream gauge Stri oil temperature gauge Stri oil pressure gauge Stri water temperature gauge Hotlap v2 laptimer Wheels/Tires: XXR 527 17x9.75 +25 wheels Nitto nt01 275/40/17 tires Project kics r40 neo chrome lug nuts Project kics 10mm spacers all around Nismo 60mm Extended Wheel Studs Last edited by brian2323; 02-14-2017 at 01:15 PM.. Reason: just a refresher |
Did you buy it from the original builder/owner? What's new with it? Any updates on how it runs now vs how it did? Or could you post a current video of it starting and running? Interested but a little far to go look at all of this
#21 | |
#25 |
Dude very nice ride i love it. Only minor quick for ur own self benefit is saying anything conforms to something shity like FD is NOT a perk or benefit to the potential buyer
#30 | |
Thanks Last edited by CandyRaid; 07-13-2017 at 03:49 PM.. |
| 240sx, kouki, racecar, rb26, track car |
