SOHC cylinder
Hello need a little people, my started loosing coolant and nothing was on the ground so did some research looks like blown head gasket. Got it off and cleaned top of cylinders of carbon and turned crank couple of times to inspect cylinder walls all good. MY QUESTION IS THIS IS # 1 CYLINDER POSITION AT TOP DEAD CENTER IS ALL THE WAY UP FLUSH WITH BLOCK ?
:2f2f |
