s15 6 speed- z32 5 speed
as the title states im looking to swap a z32 5 speed into my s15.
it is a spec r auto that has already had a 6speed swapped into it, im just wondering what else do i need to make the swap work other then the adapter plate and obviously the z32 transmission. do i need a new drive shaft? new diff? new mounts? |
Just look up info on Z32 trans installs on SR20 engines, the S15 won't make a difference when you get into changing the trans.
Basically need: Flywheel, clutch kit, adapter, mounts, trans itself, and driveshaft. If you're local to MD, I might be interested in the S15 6MT parts, help offset your cost of new trans. |
