Old 04-04-2008, 10:46 PM   #1
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
slammed cars....
dont know if this is "tech" worthy. ha
but i just did my 5 lug and my 300z brakes...and i noticed...that since i had my car low on the 15's.my is sitting really low on those 16's..has anyone written up on what to do or how to re wire/ re mount the harnesses in the wheel well so i dont burn threw the wires..
like i thought i could take off the fenders and run it higher and put the fender on again. so its not in the wheel well
any suggestions..or what have you guys done..
pictures please ^_^
thank you to all
and + rep for anyone who can answer my question
THANK YOU
HS13KLS is offline   Reply With Quote
Old 04-04-2008, 10:48 PM   #2
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
#/f/showthread.p...hlight=harness
Search harder.
Old 04-05-2008, 09:25 AM   #3
HS13KLS
^ thank you.
i tried to give you rep..but apparently i cant becasue i already have today or somthign
Old 04-05-2008, 10:13 AM   #4
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
I gotta do this shit AGAIN. Fucking 3rd time, so it's a good thing you reminded me.
Old 04-05-2008, 10:25 AM   #5
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
take that plastic wrap shit off when you relocate on the driverside. if not, you're gonna have a pretty hard time putting the fender back on without deforming it.
kensreliableb18b is offline   Reply With Quote
Old 04-05-2008, 10:31 AM   #6
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Yeah, I am gonna do that this time.
Old 04-05-2008, 10:35 AM   #7
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
Actually, my friend had a problem with rubbing through the wire even when he had it tucked up into the fender. So, learning from his mistakes I just relocated the harness through the engine bay. There are like a 4 or 5 plugs on the steering column, and the ones behind the gauge cluster and one big one near the firewall. I just took the rubber grommet from the firewall off and pulled everything out, set it neatly along the fram rail inside the engine bay and plugged everything back up inside.
louisdaboois is offline   Reply With Quote
Old 04-05-2008, 10:39 AM   #8
hotlavaflow
hotlavaflow's Avatar
hotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to behold
Send a message via Yahoo to hotlavaflow
Maybe some of you slammed guys can explain why my Teins won't let me tuck in the front. I have 3 threads left on the coilover and 2 fingers of fender gap WTF?
I got some suggestions from some other guys I have to look into but the rears also have 2 fingers of gap but at least 6 inches of thread. So I can drop the sh!t out of it after I swap out my wheels.
hotlavaflow is offline   Reply With Quote
Old 04-05-2008, 10:58 AM   #9
D1GP
D1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the rough
you can take off the lower perch i believe and that will net you like an extra 1/2" drop. you can also droop the springs.
D1GP is offline   Reply With Quote
Old 04-05-2008, 01:16 PM   #10
hotlavaflow
I understand the lower perch but what do you mean "droop" the springs? You mean like pre-load them?
Old 04-05-2008, 05:09 PM   #11
aznpoopy
aznpoopy's Avatar
aznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond repute
Send a message via AIM to aznpoopy
preload is the oppositte of droop. preload will raise the car as it compresses the spring under no load
droop is basically loose spring under no load. lowers the car because the car has to compress shock partially before it even comes to rest on the spring
aznpoopy is offline   Reply With Quote
