twincharging a ka24de ???
ok i have a s13 ka24det making like 400hp and im thinking about supercharging it too. ive already supercharged a ka before so is no biggy. my question is when using a exterra supercharger do u think is might choke the motor cause it seems like the SC is kind of small . i no they make a twincharge kit for cobras and it makes insane power with no lag ! so let me know ur opinion!
why waste the time? If you already have a "400" hp KA then it is already plenty quick. You would be all alone pioneering a huge waste of time and money. If you are looking for a way to aid in spool times then add a little bit of giggle juice.
My setup is a sc6262 with a 55 shot Zex. |
AFC #1
![]() Join Date: Oct 2003
If you are using a Screw/Rotor supercharger it won't "choke." It will just free spin when the turbo spools up.
The trick is to get a small Supercharger matched to the engine. Just maxing out at redline. Then getting a big turbo that spools up as the supercharger reaches it's peak and starts dropping off. Picking the right SC is not too hard. But getting a turbo that spools at the right time is were the art is and where you will spend the money swapping out.
I like your avatar. LOL. To be honest I think it is a big waste of time and I am not a fan of it. Its much like the guy with the 8 turbo Chevy small block that was only able to make about 800hp. There are much easier/better ways to make power and if I were you I would keep things as simple as possible esp. considering it doesnt sound like you have any exp. with twincharging.
AFC #1
Sure you can put a huge turbo on and make great peak HP. But, Twincharging is more about powerband then peak.
Twincharger - Wikipedia, the free encyclopedia You can only pick two...
ummmm yeah. I know how twincharging works . If you know what you are doing you can have a single turbo car that makes 400+ hp with excellent spool, a fat, broad powerband and good top end that is completely drivable.
And I can pick three since I have hookups. IE. Brand New Ball Bearing Billet wheel Precision SC6262- 400 bucks Tial 40mm wastegate Brand New- 150 bucks. Both of these, were cheap, are easy to use and work on, and are def. reliable. |
Let me raise this thread from the dead.. Checking to see if anyone has actually done this setup. I've seen some pics online but never a complete project or even running.
#11 | |
![]() Join Date: May 2008
"Drive it like you running from the cops" |
