![]() Join Date: Oct 2010
Hello everyone, I have quite a bit of stuff to get rid of.
Im parting out a 180sx rhd clip without the motor if you need rhd stuff. Im located in San Angelo, TX and can ship most parts! Contact me through here or text 325.212.6306 More will be added to this list as I go back through everything. RHD half cut(no motor swap, or front end)-$1200 picked up includes: -black uncut carpet -full chassis harnesses for a coupe/silvia -dash and everything under the dash -center console -door panels with power switches -steering column -rack and pinion -pedals, master cylinders -door harnesses -japanese sun visors -a few spare bit and pieces 180sx rhd full front and rear chassis harness (3 plugs missing, you can snag them from the US spec harness, came off an auto hicas model 180sx) uncut otherwise.-$350 shipped s13 silvia manual seat belts with extenders- $160 shipped SOLD ITEMS: s13 silvia bricks(set), right side lens missing, right side inner tab needs to be glued back on. -SOLD 180sx manual seat belt swap (seat belts, a pillar trim, b pillar trim, a pillar handle, no headliner)-SOLD OEM s13 silvia steering wheel in mint condition- SOLD OEM Nissan 180sx tool set- SOLD 180sx bubble side markers, one has a stress crack but both are in decent shape. -SOLD Mint s13 silvia floor mats, need to be cleaned- SOLD abs plastic s13 gtr style grille- SOLD s13 Nismo cluster- SOLD s13 rhd black carpet uncut -SOLD Last edited by Captain; 12-26-2013 at 09:35 AM.. Reason: updates |
![]() Join Date: Sep 2010
I need the sub harness for the dcc and I would take the windshield wiper linkages if you can remove them without damaging them (which is just about impossible lol). Also the kick panels, steering column surround, and the piece that goes under the dash on the driver side. I was also interested in the tool set if the wrenches, pliers, and screw driver are Nissan branded, but it looks like someone else posted about them already. I could have sworn I asked for close ups of the tool kit a couple of days ago but I must not have submitted it lol.
#11 | |
Everything should work yes |
#19 |
I have the motor and wiper arms. I just need all the stuff from under the cowl. The nuts and bolts were rusted out and stripped on my front clip so they were unusable. Then just the kick panels, column cover (mainly lower if you will part), lower dash panel, and also all the dash vents if you will part.
#20 | |
325.212.6306 |
