Old 02-07-2008, 06:58 AM   #271
driftstyre
driftstyre's Avatar
driftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond repute
Send a message via AIM to driftstyre
Sweet setup Brian. Is that in an ae86? What kind of turbo is that?
driftstyre is offline   Reply With Quote
Old 02-07-2008, 10:34 AM   #272
Brian W.
Brian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfection
Send a message via AIM to Brian W.
Thanks! Yes it was in an AE86. we recently sold that project to a fellow in Canada. The turbo was from a Nissan Xtrail(SR20VET) which is very similar internally to a S15 Spec R turbo(9 blade GT wheel and such) The car was sold with an HKS GT2530 though.
www.ma-motorsports.com
-Fab work, builds, swaps, dyno tuning
Brian W. is offline   Reply With Quote
Old 02-08-2008, 09:24 AM   #273
atown 240
atown 240 is an unknown quantity at this point
Some stuff that i've built/welded.
I'm not the best welder but i'm getting better.
Tire rack made out of shelving.
Stitch welded front end on my s13
atown 240 is offline   Reply With Quote
Old 02-08-2008, 03:15 PM   #274
alexander500
alexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond repute
I love this thread. Here is my contribution:
alexander500 is offline   Reply With Quote
Old 02-08-2008, 06:41 PM   #275
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Wow. Nice front tube frame.
blu808 is offline   Reply With Quote
Old 02-10-2008, 01:41 AM   #276
blu808
blu808's Avatar
Ok. Haven't posted some fab pics in awhile. Here is what I have been upto the last few days.
Here is a mustang cobra 13" rotor on the mill. I milled out the hub hole to fit on my fc. and s13/s14
Then I grabbed a Brembo caliper off of a Viper and mounted it up. These are extremely cheap considering most viper owners upgrade. You can find a set of front calipers for around $200.00. I can get new ones for about $145.00 each.
I will be making a kit soon for the fc, fd, s13, s14. All cnc milled. Let me know if you are interested. It should only cost around $700 including everything. Calipers, pads, hardware, stainless lines, an fittings, rotors, brackets, etc. This is retarded cheap.
Then I had a new project to do. SJSU had a electric car they were building and needed a steering wheel adapter. Since there was no adapters available in the size they needed, I had to make one. It started out as a 3" piece of aluminum. This is what it looked like 8 hours later.
|The post is to hold a thumb throttle.
Heres the steering shaft that I tig welded. Looks like a piece of jewelry in person.
Then it was lunch time. So I made the intercooler piping for my ls1 turbo FC.
Then I bead rolled it for that professional look.
Fits great !
other side
yup
Hella room
O yea. Then I decided to make a custom power steering cooler/ line setup for my fc. It ended up costing over $600 my cost just for all the lines, fittings, cooler. OOPS> lol
Then I started to work on this Cobra kit car.
It has a BB chevy in it. :-0
Custom headers.
321 stainless.
Cool suspension and ewwiwops.
Then I was like shit. The owner wants the shifter to be 3" longer. So i grabbed some aluminum and headed over to the mill..
Turned out sick
I dont have a pic of it welded up, but that looked good as well.
Then I had to weld a nut onto a steering shaft support.
Looks like a weld that belongs on the space shuttle in person.
Then there was this baracuda
And roadrunner which we will be twin turboing with fuel injection.
Stay tuned.
Old 02-10-2008, 01:59 AM   #277
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
I would probably be intrested in that Brake kit later this summer. That is a AWSOME price!
I got a couple of questions:
What pads would be included?
Would it clear a 17inch rim?
How over kill are these going to be on a S chassis, dont want to be locking up my brakes all the time.
KA-T_240 is offline   Reply With Quote
Old 02-10-2008, 02:20 AM   #278
blu808
blu808's Avatar
Surprisingly these calipers dont use much more volume than the z32 brakes, and since they spread it out over a larger pad/ rotor area, the braking should be great. We would suggest that the 240 guys use a z32 master cyl. but it is not req if using a prop valve.
Old 02-10-2008, 02:51 AM   #279
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
Damn Luke, wish you were local. I could use a good welder. Is that IC piping steel?
Seller feedback>>#/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 02-10-2008, 03:01 AM   #280
blu808
blu808's Avatar
Thanks.
No. That is some fine cheap ass china aluminum. lol
Old 02-10-2008, 03:09 AM   #281
KidSaru
KidSaru's Avatar
KidSaru has a brilliant futureKidSaru has a brilliant futureKidSaru has a brilliant futureKidSaru has a brilliant futureKidSaru has a brilliant futureKidSaru has a brilliant futureKidSaru has a brilliant futureKidSaru has a brilliant futureKidSaru has a brilliant futureKidSaru has a brilliant futureKidSaru has a brilliant future
Jesus Christ, update on the TT Roadrunner asap. +1
KidSaru is offline   Reply With Quote
Old 02-10-2008, 09:30 AM   #282
wannabe_drifter
wannabe_drifter's Avatar
wannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to behold
blu808 : your job looks like a lot of fun !!!!
Insane baracuda, and yea updates for the TT roadrunner when you get going !!!
http://i123.photobucket.com/albums/o308/two40/Mine/CoupeSte-Croix.jpg
wannabe_drifter is offline   Reply With Quote
Old 02-10-2008, 06:48 PM   #283
KA-T_240
Ok, Let me know more info as it becomes available. Any Idea if it will fit on a 17inch rim?
Old 02-10-2008, 07:13 PM   #284
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
ok luke, can you explain how you find out WHERE to drill on the rotor to keep its balance? ....is it just alot of measuring? details mang!!!
burnsauto is offline   Reply With Quote
Old 02-10-2008, 07:31 PM   #285
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
Wow blu808 i wish i had ur skills and shop ur skills are just awesome.
Old 02-10-2008, 07:38 PM   #286
blu808
blu808's Avatar
kidsaru: Workin on it.
wanna: Workin on it.
Kat: Should fit on 17" wheels.
burnsauto: It is pretty simple. Since we are just making the existing center hole larger. Just determin how big you would like the hole to be. Then cross measure from a symmetrical reference point such as the 5 lug stud holes.
Once you have it close to be aligned you can use a dial indicator to determine your tolerances. In this case about .008 +-
Old 02-10-2008, 07:39 PM   #287
blu808
blu808's Avatar
Thanks. Im sure if you had a shop like ours you would be able to make some cool stuff as well.
Old 02-10-2008, 10:25 PM   #288
KA-T_240
Ok, hopefully it well. Since you are re-drilling the holes for the wheel studs, Is there a chance at 4-lug?
Old 02-10-2008, 10:33 PM   #289
blu808
blu808's Avatar
Kat: I am actually not drilling new holes for the studs. I am simply making the center hole larger.
I could re drill them for 4 lug. I would have to check my cost though.
Old 02-10-2008, 11:07 PM   #290
250sxdet
250sxdet will become famous soon enough250sxdet will become famous soon enough250sxdet will become famous soon enough
Those brakes look awesome...I'd be interested in picking a set up for a track car thats in progress. Do you plan on doing a similar setup for the back?
250sxdet is offline   Reply With Quote
Old 02-10-2008, 11:14 PM   #291
blu808
blu808's Avatar
Yes. But with my current schedule it may be awhile.
Old 02-10-2008, 11:17 PM   #292
250sxdet
That sounds great! Im not in a big hurry. Keep us posted with the good work.
Old 02-10-2008, 11:18 PM   #293
KA-T_240
Ok, not a biggy. Completely misread your post. I can do it also. I'll try to watch this thread for info on when this becomes available.
Old 02-14-2008, 11:31 PM   #294
badrifter
badrifter is a glorious beacon of lightbadrifter is a glorious beacon of lightbadrifter is a glorious beacon of lightbadrifter is a glorious beacon of lightbadrifter is a glorious beacon of lightbadrifter is a glorious beacon of lightbadrifter is a glorious beacon of lightbadrifter is a glorious beacon of lightbadrifter is a glorious beacon of lightbadrifter is a glorious beacon of lightbadrifter is a glorious beacon of light
You guys are good!!! ^^^^^^^^^^^^^^^^^ I thought my custom intercooler piping for my in front of radiator mount me and my brother made was cool.
Here it is..........
i didnt want to take up much room so here are more pic links.
http://i249.photobucket.com/albums/g...r/CIMG0685.jpg
http://i249.photobucket.com/albums/g...r/CIMG0686.jpg
http://i249.photobucket.com/albums/g...r/CIMG0688.jpg
http://i249.photobucket.com/albums/g...r/CIMG0683.jpg
http://i249.photobucket.com/albums/g...r/CIMG0684.jpg
Girlfriend or car, which is more work????
badrifter is offline   Reply With Quote
Old 02-17-2008, 03:16 PM   #295
Ghostdrifter
Ghostdrifter is making a name for him/her selfGhostdrifter is making a name for him/her self
Super modified tein tension rod
gotta finish it and do the other one
Ghostdrifter is offline   Reply With Quote
Old 02-17-2008, 05:05 PM   #296
Swerv13
Swerv13's Avatar
Swerv13 will become famous soon enoughSwerv13 will become famous soon enoughSwerv13 will become famous soon enough
OKay heres the final update to the fabwork done on my fastback. and this time final isnt a good meaning.
About to weld in the rear strut tower bar, i was planning to position the battery to this tube but im not sure about that. would the weight of the extension relocation kit cancel out the advantage of moving weight back? would i be better off with a small battery in the engine bay? OPINIONS please.
Almost done with the cage here......see some of the seam welding on the rear wheelwell?
OK look at the roof area....now some people (mostly drag setups) do a halo design, but i chose to make mine full A pillar tubes back to the main hoop. the compound bend makes it more complicated than a halo bend, i like this much better tho. OPINIONS PLEASE?
HAHA I found thos Foam Squares in the sides of the chassis, now they are more usefull. Fuzzy dice hanging like testicals. my best fab job ever.
And doing some fitment decisions for the sideimpact Xbars with the stock seat.....
And then this happend....
Here is my new car....soon she will have her own posts in this thread as well.
-Erven
Swerv13 is offline   Reply With Quote
Old 02-17-2008, 05:55 PM   #297
atutt
atutt's Avatar
atutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond repute
/\ Sorry to see that man. Just turn all the frustration into something positive and the coupe will turn out much better than anticipated.
atutt is offline   Reply With Quote
Old 02-18-2008, 10:58 PM   #298
blu808
blu808's Avatar
Lol at dice.
Cage looks cool.
I like the new coupe.
Old 02-19-2008, 12:00 AM   #299
slw240sx
slw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant future
Send a message via AIM to slw240sx
lol, i found one of those little foam dice hiding in my Apillar area when i was stitch welding it, only i found it after the whole pillar was engulfed in flames.. i ran around for a few seconds trying to find something to put it out with, ended up pouring a gallon of lemonade on it. melted a little of my windshield and left me with a huge sticky mess to clean up... Now i have either a fire extinguisher within 2 feet of the car or a gallon of water lol.
http://www.forcedfabllc.com/
slw240sx is offline   Reply With Quote
Old 02-19-2008, 09:45 AM   #300
Brian W.
ive had the same fire experience with the foam in the pillars!!!! hahaha
