| Media Forum / Pictures / Videos Forum dedicated to media, such as pictures and videos. |
My 95 240sx Fun project...
A few people might know of this car. It was built by a previous person i am just making it better and making changes to it.
When i got the car it had a shit load of vac leaks, a big ass oil leak, a SHITTT LOAD of dynamat (43lbs of it) ......Ive just been slowly changing things and working on making the car better, Ive found all of the Vac leaks and capped off alot of stuff that should have been. The car is now running a full 20psi and gets there instantly!! Heres the build sheet-- S13 Redtop SR20det CP 86.5mm / 8.5:1 compression pistons Eagle H beam rods Factory nissan main bearings and rod bearings and thrust bearings Bottom end assembly balanced (westside performance) Crank polished (westside performance) Block decked (westside performance) Head decked (westside performance) New oem oil pump/timing chain cover New oem timing chain assembly New oem oil strainer/pickup New s14 sr water pump Nismo thermostat Circuit sports water pump and powersteering pulleys ATI crank pulley damper New drive belts Mishimoto radiator and fans JWT S4 cams BC +1mm intake/exhaust valves BC spring and retainers New oem valve guides Supertech valve stem seals New oem rocker arms New oem rocker arm guide and shims P2M RAS New alternator New oem front main seal New oem rear main seal New valve cover gasket Cosworth head gasket ISIS intake manifold Aeromotive fuel pressure regulator Walbro 255 fuel pump engine harness wire tuck Garrett GT3071R 63 a/r turbine w/ 3" v-band Turbonetics evolution wastegate turbo blanket Treadstone topmount cast stainless steel log manifold 2.5'' downpipe to 3'' full exhaust with apexi turbo N1 muffler braided SS oil and coolant lines w/ JIC fittings. AEM wideband Defi boost gauge Nismo 740cc injectors When i first got the car...... Then after 7hrs of detailing with all kinds of stuff and a toothbrush, i finally got the engine bay looking new again Thennnnnn, Well then shit got a little crazy and i wanted to stand out but yet look good still. So i chose a whacky color to go with... And here is where shes at today! Then i repainted the bumper because it had all kinds of rock chips and the paint was just peeling off like crazy everywhere ANd Finally for now.....Here is a video of what the sr20 does with a nice beefy GT3071R at 20psi. Of course there are a shit load more mod's, so dont be that guy asking. Lol 240sx GT3071R sr20 - YouTube |
