I'll start off by saying I'm very knowledgeable about this motor and car. Been reading, researching and diagnosing for months and as a last resort here I am.
Car fires right up when I put a jump pack on it. As soon as I kill it and fire it back up just cranks and cranks. New battery, coilpacks, ignitor, spark plugs, cas, alternator, starter, Injectors all read 12.0v checked and re checked grounds. I'm stumped If anyone has had a similar issue I'd love you know what you did to fix it. Much appreciated |
Spirit Of Ecstasy
![]() Join Date: Dec 2007
Have you tried putting a fresh battery in? Its also possible under load the voltage is just dropping. (bad cell) Also jump it & while its running disconnect the battery completely. If it stays running alternator is good or if you have a multi-meter just check voltage at the alternator while running.
After splitting my head trying everything. I swapped ecu. I should have mentioned before that I am running AEM v2. Swapped with a stock one and it fires right up. Swap back and just cranks. I'm now searching AEM forums as most people here don't have that much in depth experience with tuning. My tuner who is very highly regarded. After he tuned it it started fine but this problem has progressively gotten to this point. I'm gonna run 2 batteries is parallel until I can find a permanent solution
![]() Join Date: Jun 2003
Trader Rating: (129)
when its cranking but not starting, have you checked for spark / fuel injectors with a noid light ?
Full boost. Have you heard of something similar to this situation. It is just so odd it would run so good and start with was when jumped. I was hoping it was some stupid setting in the AEM
