S14 Kouki OEM Sideskirts - Can you install w/o endcaps?
Just picked up a set of OEM side skirts for my 97 kouki without endcaps. Seeing that they're kind of hard to find cheap, just wondering if you'd be able to install them without the end caps. Also, if I do install them w/o the end caps and find a set of end caps later on, how hard would it be to add the end caps to the skirts already installed?
Thanks |
I'll hit u up about that soon. Do you know if I can install the end caps after I've installed the skirts already? I have a base model and i'll be drilling and using double sided molding tape and don't want to have to go through the trouble of taking them off just to put the end caps on.
![]() Join Date: Mar 2008
I left mine out. At 200mph the holes act like an air extractor and create a good amount of downforce on the car.
Leave them off or you risk dying after your car lifts and explodes into a huge fireball. |
| end caps, kouki, s14, side skirts |
