Ka24de removed emissions help
Ok so this is my first 240sx and I just replaced the motor,
1st start the car was running fine but it had all the emissions and vaccum lines all hooked up. Anyways had a coolant leak at the steel line under the manifold,so I replaced the intake manifold and deleted pretty much everything All I have hooked up is the line from the brake booster, the one to the fpr and one from the iac to the intake. Capped the one under the throttle body.. I say it's running rich because car reeks of fuel and I have fuel on top of my pistons. On cold starts I also have to tap the gas and she fires right up weird .. I decided to just remove it because it was easier and a friends car deleted his and his car runs fine I just want to know if I forgot anything else or what can I do, I can't put the egr back on because I broke the pipe to the exhaust. Searched on forums for days and cannot really find anything specific in my situation... |
Thanks for the reply , yes I did and the car is a 1993 nissan 240sx , the car idles perfectly at 750.. when I come to stop tho it stays at 2k and drops slowly if that means anything?
