Car does not start anymore... :( help...
Ok. Here is the situation.
Never had any problems with starting the car in the past 8 month that I owned and started like new. But as of yesterday, I’m having problems starting it. When I turn the key to start it, all the light comes on and I fans can blow and all that. But I can’t really hear anything from under the hood, motor is not turning over and don’t hear any sound from the starter. There is some clicking from the fuse/relay boxes, one by the battery and one by the air box…. Just a little click when you try to start it. So basically I have power, but nothing turns. The only way I’m able to start it is from a push start. Any ideas? Could it be the starter? I went to Advance and had them check out the battery and starter and they said everything looked good (not sure how much their word is worth.) Thanks guys.
huh? |
![]() Join Date: Sep 2002
Make sure all your connections are tight. If it keeps doing that and it will work after hitting it with a hammer then you need to replace your starter.
My 240 vBgarage |
