Sun Hyper Ground & Hot Inazma Install
We just added a new install write-up to our site. This is for all of you who are interested in voltage/grounding sytems.
We installed the Sun Hyper Ground and Sun Hot Inazma systems onto our IS300. Click here to view the install |
#3 | |
AFC #1
![]() Join Date: Oct 2003
The MSD and Crane are Ignition boxes. This is a capacitor in a fancy box. |
*GorgeousGarage* L.oose S.ocks D.aisuke ! |
#6 | |
AFC #1
Sounds like a Capacitor to me. Just like you would have on a stereo system before the amps. I see nothing that would indicate anything to do with a igniton system. |
![]() Join Date: Jan 2003
Instead of reading the description, just look at where they hook it up to. It can't possibly be the same as a real ignition box like MSD, it's not even hooked up to the ignition system in any way..........
#8 | |
#9 | |
I hate you too...
![]() Join Date: Jul 2001
CDI is capacitive discharge ignition [system]. The ignition box itself stores power and releases it during the ignition cycles. This box is a capacitor, designed to keep the voltage steady in the car's electrical system (in theory). There is a massive difference between a full-on ignition system that has capacitors in it, and a capacitor in the box attached to the grounding system. -Jeff
Whatup? |
![]() Join Date: Sep 2004
my friend also go that, it's pretty good! the response of the car has improved a lot
~小アレンのリベリオン~ いくせ, 勝負た! 轟こう, オレのKRMS13!!! オレの得意技!蹴り進入!角度の少ないドリフト! |
