![]() Join Date: Jun 2015
s14 oem parts misc, s13 coupe rear bumper,z32 spindle
S13 Oem coupe rear bumper, no cracks or dents ,primered 30$
S14: Driver window amplifier , still works you can test it first if you want 30$ and I have another amp that just makes a clicking noise if you're interested Tension rods need bushings 20$ Oem Brake Master cylinder no leaks 15$ Oem calipers with brake lines , brake pads, e brake cables and 5 lug rotors 70$ 6 bolt axles with axle nut and bolts to diff 50$ Oem se wing clean black paint 40$ Cigarette lighter (still works good I just had a short in my wiring) with 12v plastic cover and light ring (still lights up bright) 30$ leather rear seats top part is ripped and has cracks bottom is clean 20$ Z32 Right rear side only spindle 10$ Prices are picked up , obo , located in 91752 , text 626 606 7381 Last edited by Zenki_Ray; 01-21-2016 at 05:58 PM.. |
| j30, ka24, s13, s14, z32 |
