Is this fixable?
Long story short, ez out broke in a broken stud removal process. So I had to hack the stud hole.
So my question is, can aluminum heads be filled up and re-tap for a stud? Very stupid mistake, and feel dumb as shit for asking something like this, but any advice would help. _ oz
IG: @ozc2jz Last edited by oscarsx; 05-11-2017 at 08:33 AM.. |
![]() Join Date: Jun 2010
Yes but depending where you take it, may not be cheap as they would need to clean the head, have someone with a tig welder fill it, then someone to drill and tap it. If you didnt get the broke stud out, then you will need to pay someone to extract it and fill it as well or just extract it and fill the opening a bit wider where it wont need threads.
I got a free head because of a similar issue.
S14 KA NA two cylinders, 75whp limper |
![]() Join Date: Aug 2010
Trader Rating: (43)
![]() Feedback Score: 43 reviews
Going to be more work than it's worth, remember once they weld they will have to deck both the intake manifold flange and the head mating surface due to the heat.
