#21061 | |||
GM2 (SW/AW)
use the search at the top right, these things are still around in the OEM metal. Quote:
There are a few threads floating around currently that have the OEM metal fenders you're looking for. zilvia.net/f/search.php?searchid=16592393 #/f/showthread.php?t...t=Kouki+Fender
#21062 |
![]() Join Date: Apr 2008
KA24DE
Anyone know the bolt size for the Knock Sensor? I know its a 12mm. I need the thread and pitch.Mine fell into the rats the nest of an intake manifold. Tried using a magnetic snake tool, no luck. Thanks |
#21063 | ||
GM2 (SW/AW)
I can send you one for the cost of shipping. $2.67 but if I'm not mistaken you can bolt the knock sensor to a couple different areas on the block. I've had KA's with them in the center under the manifold runners, I've had blocks where they're bolted right above the water outlet. I have a huge bucket of bolts so maybe it's easier for me, but there should be about 3 other items in the area you can snag a bolt from and using to match up with at your hardware store.
#21064 | |
https://parts.nissanusa.com/ 08120-8301A Had part numbers for literally everything. Looks like Nissan USA IS good for something these days. Its an M8x1.25, the home depot down the block has 5 in stock ![]() |
#21066 | |
![]() Join Date: Jan 2008
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
So here's my set up please fill in the blanks (Knuckle), s14 inners, (outers), Cusco tension, 25mm flca's in the brackets I need these pieces to make an angle kit. If anything I'll probably add inner rod spacers but that's it. What would be a functional angle kit that's still streetable Sent from my iPhone using Tapatalk |
#21067 | |
Trader Rating: (92)
Noob question but roll center correction knuckles by any chance could you recommend some? Sent from my iPhone using Tapatalk |
#21068 |
![]() Join Date: Jan 2009
Trader Rating: (25)
Hey guys, before I buy a new alternator I figured I'd ask first. My alternator has a high pitched whine ONLY when it is engaged. If I unplug the 2 wire plug that kicks it on, the whine goes away(and the charging obviously).
My problem is this is 2 alternators that have done this now. Both are charging at a solid 14+ volts no problem. Battery is mounted in the stock location and using the stock wiring harness. I have no issue upgrading to the Quest alternator, but I don't want to buy that and run into the same issue.
#21069 | |
GKtech knuckles are known to crack. I've heard no bad news with PBM ones, I just prefer custom fab shit and supporting those who do it. But I have a question of my own that I think would help you out as well. WHAT FUCKING YEAR MAXIMA OUTERS DO I USE?? Every thread is like "maxima outers" with no year given. I don't buy shit like this without knowing a year range, how can a mod this common be so poorly documented? Thanks.
WTB SR20 *Non-Rep* Bottom Mount Manifold WTB Bride Zieg II |
#21070 |
![]() Join Date: Jul 2006
Check out my build thread! #/f/builds-builds-on...rhd-build.html |
#21071 | |
Sent from my SM-G930P using Tapatalk |
#21072 |
![]() Join Date: May 2012
^^^ Those look like JDM S14 footwell lights. They look like they sell anywhere from $150 to $400 from what I can see.
Follow me on Instagram or don't @cason880 |
#21073 | ||
![]() Join Date: Jun 2010
#21074 | |
I guess "known" was a bit far but I followed this guys builds and he is not a dummy. I've read through the RC thread a few times over the past few years, and recently went through again. it mentions years and lengths, but nothing really about outers. I also have a hard time believing everyone running maxima outers combed through that thread to find the answer. I'm more concerned with the ball joint shank size than the inner thread. I want someone to point me to an obvious answer that I'm too dumb to see. Unlike a lot of people I need to see concrete evidence before I spend money on parts not made for my car.
#21075 |
In exchange for that awesome link, I'll spill the beans. The Maxima outer that is 1" longer than S14, which I assume is the one you're looking for, is from a 1990.
Maxima outer on the left, S14 on the right: ![]() |
#21076 | |
Thank you. Guess I will post up a for sale thread for em.
#21077 |
New question from me.
Is there a difference between spaced tie rods (like using a spacer) and longer tie rods? As I see it, all that matters is overall reach from the rack to the ball joint on the outer end. Is there something I am missing?
#21078 |
That might be a better question for the RC thread, but with a spacer you are moving the inner pivot point. And that will affect suspension / steering geometry. I imagine that it's bump-steer that would change. Probably not by much though.
#21079 |
Well I'm back guys.... the thing is my car started to have this bogging out sound at idle and when revving it and it also started to shake much more. I searched and searched and I only came up with the conclusion that it could be my MAF, spark plug wires, the spark plugs themselves or an o2 sensor. The symptoms are as follows: hard to start especially on cold mornings, much more shaking and it sounds like it's bogging out. Here are some pictures of the prongs on my MAF.
![]() I also recorded the sound of my car, if anyone would like to help me I could upload it to YouTube for you guys. Sent from my iPhone using Tapatalk |
#21080 |
Admin Asshole
![]() Join Date: Mar 2002
Do you have any larger pictures? I can almost climb through my monitor and into the plug to figure it out from the inside.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#21081 |
It's from my phone camera, and uploaded from my phone as well. I'm sorry if that's an inconvenience to you :/ I can't see how big it actually is but hopefully someone will be able to see it better
#21082 | |
Clean the maf sensor (carefully!). Have you modified the car recently that could cause this? If its constantly "bogging" could you be mistaken for a misfire? Sent from my iPhone using Tapatalk |
#21083 | |
Bro I just took apart try MAF sensor check this out LOL ![]() Sent from my iPhone using Tapatalk |
#21084 |
#21087 | |
It's a fresh upload so I'm not too sure bout they quality, let me know how it is. http://youtu.be/Fk7_6Ay5Kyw Sent from my iPhone using Tapatalk |
#21088 |
[QUOTE=Halobb;6199954]It's a fresh upload so I'm not too sure bout they quality, let me know how it is. [url]http://youtu.be/Fk7_6Ay5Kyw[
Does your temp gauge work. Sent from my iPhone using Tapatalk |
#21089 | |
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
[QUOTE=tomtom8228;6199957]
Yes it was fixed recently, I always let it warm up before I take it out if that matters lol Sent from my iPhone using Tapatalk |
#21090 |
Is there a trick to removing the A/C evaporator hard lines by the firewall? the ABS module is in the way and has no wiggle room because of the brake lines. G*d damn ABS!
| 180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
