![]() Join Date: Apr 2005
SR20DET Garage Sale (OEM and Aftermarket)
cleanin out the garage...
Brian Crower stage2 cams (264/264 12.04) $SOLD Brian Crower valve springs and Ti retainers $SOLD ARP head studs. used but as you know they can be REused $75 Greddy RAS. $SOLD (2) sr20 shortblocks. $200/ea sr20 head.. bare.. all cam caps are in original spots and i will include all the locks, rockers, and lifters. $SOLD sr alternator $SOLD sr starter $SOLD sr power steering pump $SOLD (2) sr oem intake manifolds with good iacv $50/ea sr CAS. clip is broken on one side but it works fine $125 oem exhaust cam gear $30 (3) valve covers... all could use a good paint or polish or pc $50/ea (2) upper oil pans $50/ea (2) lower oil pans.. one is mint the other has been banged out... both 100% usable $40/ea Coil packs $40/ea Coil pack harness $50 Z32 aluminum Rear Uprights $75 oem cams... worn but i guess they could be used for a re-grind or some garage decorations $20 oem flywheel, less than 100 miles since fresh surface job $100 (4) oem timing chain tensioners $25/ea oem tranny backing plate $25 3" stainless 45degree angle long radius.. bought it from atp to make a downpipe but i didnt use it.. was like $50 $25 s13 open diff in pumpkin $50 \ large pics of everything can be seen here garagesale pictures by ansky3351 - Photobucket all prices do NOT include paypal or shipping located in NY zip 12540 Last edited by aNskY; 05-19-2009 at 06:58 PM.. |
#16 | |
