Old 09-06-2009, 11:41 AM   #61
Silkroad FC
Silkroad FC can only hope to improve
I have 2871r .64 trim and I love it, car makes oodles of fuckin' power and the power band is good.
Silkroad FC is offline   Reply With Quote
Old 09-06-2009, 09:34 PM   #62
BRAIN_Z33
BRAIN_Z33's Avatar
BRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfection
BRAIN_Z33 is offline   Reply With Quote
Old 09-06-2009, 09:47 PM   #63
S14_Kouki
S14_Kouki's Avatar
^ is that all you got ahahahahah
So does anyone have anything other then a 30r or 2871?? or is everyone just the same.
S14_Kouki is offline   Reply With Quote
Old 09-06-2009, 09:53 PM   #64
Tom25666
Tom25666's Avatar
Tom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choices
go big or go home, that's what i say
I have 1000 hp. This thread is dumb.
Tom25666 is offline   Reply With Quote
Old 09-07-2009, 12:31 AM   #65
STR8E180
STR8E180 is an unknown quantity at this point
not me
turbonetics GT-K 500
STR8E180 is offline   Reply With Quote
Old 09-07-2009, 02:28 AM   #66
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
I have a stock t25 but i like the way Disco potato sounds so maybe eventually ill get that if this is not enough lol
om3ga is offline   Reply With Quote
Old 09-07-2009, 04:24 PM   #67
S14_Kouki
S14_Kouki's Avatar
^ your buying a turbo by the way it sounds??
Old 09-07-2009, 04:51 PM   #68
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
Best turbos for the SR20DET
GT3071R, GT3076R, GT3582R
Best way to get the most out of all the above turbos with an SR
1. dont buy into the Greddy IM madness, keep your stock IM
2. Modify your stock im to use a Q45 TB
3. Use a lightened Flywheel, lighter drive-shaft and lighter clutch unit
4. Don't Over do your injectors, buy just the right size, i.e. 740 for 3071R, 800 for 3076R, 850-1000 for GT35R
5. Less un-sprung weight the better, that means LIGHT RIMS, especially on the drive hubs
This will add up to a VIOLENTLY fast spooling and complimenting setup.
For example I would love to see someone on the board do an SR with Q45 TB, Lightest Flywheel from ACT + ACT Clutch Kit, CF Drive Shaft, Super Light Volk Rims, STOCK Intake Manifold.
The car would spool up 20 PSI of boost before 4k rpms and the rev would be so violent that the car would probably be hard to drive.
I would guarantee that this setup at 400 whp would be faster in a straight line than a 500 whp car with heavier driveline parts and larger laggier IM and turbo.
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 09-07-2009, 05:19 PM   #69
Sileighty_85
Sileighty_85's Avatar
Steve you know anyplace that that will weld a Q45 T/B flange on to the stock SR intake manifold?
I was just thinking about this 2 days ago when i came across 2 Q45 TB in the junk yard So now i got one for the RB and one for my SR.
I've been wanting to keep the Stock IM for my low end and increase flow into it.
Do you know how well that will work out?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-07-2009, 06:17 PM   #70
driftage240
driftage240's Avatar
driftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfection
Send a message via AIM to driftage240
^^^ cant i just use the tomei bb tb? instead of the q45?
Misty blu is coming 4 you!
driftage240 is offline   Reply With Quote
Old 09-07-2009, 06:28 PM   #71
Sileighty_85
if you wanna spend $700-900 for it, when a $27 TB from a junk yard does the same thing.
I belive you still have to weld a flange on(or it uses some kind on double bolt on flange) and port match it.
後輪駆動車1番
1986 SR86 - 200ish
Old 09-07-2009, 06:51 PM   #72
sr20drifter1
sr20drifter1's Avatar
Trader Rating: (66)
sr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nice
Feedback Score: 66 reviews
Hks
If you need very good response on short distances, I will go with Garrett 2860 or HKS GT-SS. I used to have HKS2540R. It was good,but a little laggy. When I drove TF Dave's Coupe, I was blown away by the car response. It had a HKS2530. It was so fast and fun to drive. I then switched mine to HKS 2530. I put Tomei step one cams and retuned it. I hit full boost at about 2000 to 2500 rpm. The only thing that's left to do is a Full Race bottom mount manifold for better high end. I hope you get what you're looking for soon. Good luck.
DAOUD AKA KONGO DAVE
sr20drifter1 is offline   Reply With Quote
Old 09-07-2009, 07:44 PM   #73
Black240Ct
im getting into this myself
s14 sr
Greddy easy cams, elbow and down pipe
tomei mani
right now im running 15psi on a stock s14 turbo with a stock tune
looking into a 3071r-wg bottom mount or a 2871
the car is used for drifting. debating on the best set up for this
should i run a 3071 or 2871
looking for good response not super high horse power
Old 09-07-2009, 07:52 PM   #74
smelly240
smelly240's Avatar
smelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfection
street cars work good with those...
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 09-07-2009, 07:56 PM   #75
S14_Kouki
S14_Kouki's Avatar
Fuck Full Race ill build you a better manifold for cheaper
Also steve shadows its not always the best to have the lightest drivetrain as poss. You dont like torque??
Old 09-07-2009, 09:01 PM   #76
SixSpeedSleuth
SixSpeedSleuth's Avatar
SixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to behold
GT30R Twin Scroll and Love it.
SixSpeedSleuth is offline   Reply With Quote
Old 03-28-2010, 10:40 AM   #77
mystacarlo
mystacarlo is on a distinguished road
i went with an old school Turbonetics t3 60mm front wheel and 59mm back wheel, bought it of $300 off a mustang guy.
Made 404whp and 321torque @ 21lbs on a dynojet
mystacarlo is offline   Reply With Quote
Old 03-28-2010, 11:07 AM   #78
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
im a guy that loves lower boost levels(less headaches) and good power. T2 flanged turbos make me happy my old HKS 2530 was AMAZING. even at track like horse theif i was up shifting into 3rd on the downhill and didnt have any trouble chasing 400whp cars.
Grenade180sx is offline   Reply With Quote
Old 03-28-2010, 11:09 AM   #79
mystacarlo
i made 296whp at 13lbs and is fun on the road, and i manage the traction issue with sum 275/35R18's in the rear, so all i hav is solid pull to redline
Old 03-28-2010, 04:36 PM   #80
docrez
docrez's Avatar
docrez is an unknown quantity at this point
Send a message via Yahoo to docrez
I just orderd a Borg Warner/Bullseye S256. Spools a little later than the GT3076r but it has way more top end potiental. I'm also .20 over...
docrez is offline   Reply With Quote
Old 03-28-2010, 10:24 PM   #81
pinkarrowsnow
pinkarrowsnow's Avatar
pinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura about
welll heres some words of advice just sold my built ka t3 60 trim decently sized turbo to a 98 sr with vtc the ball bearing 28 and holy shit the car is amazing with this setup i love it bearly any lag plenty of power 450cc injectors z32 maf jim wolf tune its awesome maybe will do bigger injectors and 2871 but who knows i love my car all over again big turbos arent that cool and this isnt my dd btw
pinkarrowsnow is offline   Reply With Quote
Old 03-28-2010, 10:41 PM   #82
Grenade180sx
use periods!!!
Old 03-28-2010, 10:54 PM   #83
Odysseus
Odysseus is an unknown quantity at this point
I run an S15 turbo on my SR. 323WHP/278TQ @ 14PSI. Super fun setup. Fast spooling and nice power on the streets.
Odysseus is offline   Reply With Quote
Old 03-28-2010, 11:29 PM   #84
Patrick Bowering
Patrick Bowering's Avatar
Patrick Bowering is an unknown quantity at this point
I am just about done my build. It is a twinscroll gt3071 .78ar, stock s13blacktop, isis intake mani, haltech standalone and 740cc injectors looking to run 14-15psi. Does anyone have anything along the same lines? Just curious about what numbers I will make. It should be getting tuned within the month so I will post up a dyno sheet after tuning.
Patrick Bowering is offline   Reply With Quote
Old 03-29-2010, 12:12 AM   #85
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
(GT28RS)Disco potato .86 would work nice with your cams.
huffandpuff00 is offline   Reply With Quote
Old 03-29-2010, 09:09 AM   #86
Grenade180sx
what is your motor setup?
Old 03-29-2010, 09:13 AM   #87
SuperiorS14
SuperiorS14's Avatar
SuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-known
i run the t2 version of the 3071 with escort racing manifold w/44mm wastegate, 272's, 740cc tuned on pfc made 389whp on 91oct
SuperiorS14 is offline   Reply With Quote
Old 03-29-2010, 09:58 AM   #88
airhead
airhead's Avatar
Trader Rating: (32)
airhead is making a name for him/her selfairhead is making a name for him/her selfairhead is making a name for him/her self
Feedback Score: 32 reviews
s14 bb turbo @16PSI i believe
still looking to get z32 maf,550cc injec,tune,FMIC. see how that goes
or i might just get tune and FMIC... idk yet
airhead is offline   Reply With Quote
Old 03-29-2010, 10:19 AM   #89
S14_Kouki
S14_Kouki's Avatar
I have now upgraded to a evo9 turbo
Old 03-29-2010, 10:48 AM   #90
sirfallsalot243
sirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enough
Currently: Bone stock KA
Just bought a redtop this weekend, and I think I'm gonna skip the t25 entirely and just go with an s14 t28. I can pick one up for 200 bucks, and the motors already out. Might as well.
sirfallsalot243 is offline   Reply With Quote
