![]() Join Date: Apr 2013
Is this a real question?
Of course they do. Them being a 2.0L and a 2.4L makes no difference. Neither does the fact that the blocks aren't very similar. Go do the change now ![]() |
![]() Join Date: Sep 2005
It's OK in situations like this, to mention who told you such BS!
There are engines with the same code where the gaskets do interchange s13sr and s14sr you can use the s14 gasket on the S13sr with no problems.
![]() Join Date: Jun 2003
Trader Rating: (129)
Jeezus this is why we can't have nice things.
Hey I've got a 1uzfe and an ls1. Since they're both v8 do you think I can put the LS cam in the toyota engine??? |
![]() Join Date: Sep 2008
Alright besides the fact this question is completely senseless im going to answer just because i feel like it may do you good.
No..... it is not compatible.. Ka and SR are entirely different motors.. the only thing they share is the fact they are both made by nissan. Please dont work on your own car.
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
![]() Join Date: Jun 2008
the only thing i can think of that is compatible with both engines is the knock sensor and oil pressure sender. injectors are the same fitment, different cc. dont think anything else besides that is interchangeable on the block.
![]() Join Date: Jul 2005
the knock sensor is not interchangable. If someone finds out that the part numbers are the same... well.. I should be very surprised and... interested.
![]() Join Date: Feb 2004
Ok, so since the sr20 is a 2.0 and its made in Japan can't i use a B20 head gasket from Honda? I mean its made in Japan and its also a 2.0. Also make sure you get some more headlight fluid, seems to me yours is VERY LOW!
#17 |
Lmfao.. Different displacement, different block, and especially different piston bore size. Ka are 89mm sr are 86 I believe. I'm ka-t so I'm not an expert on SR. Off the top of my head the only thing the same of the two is the thermostat. You really should had looked at an actual head gasket and compare the two side side by side and read the specs before making your self look like a fool. Kids these days, expects to be spoon fed.
