![]() Join Date: Apr 2004
S15 Speed sensor
Does anyone know where to buy an S15 Speed sensor (for the Diff) I'm Getting nowhere with thie everywhere else I've looked includeing friends in okinawa (got me an engine, transmission, driveshaft, intercooler but couldn't find the LSD with speed sensor).
You don't need the s15 diff, you can use the ka speed sensor and (plastic)worm gear. The worm gear needs to be shortened and bored.... the 6spd has a plate blocking off a hole were the ka speed sensor goes.
worm gear dimensions = .550" lenght bored to 1.11" you also need: 2 c-clips thickness .095" and ID (inside diameter) 1.030" 1 ball bearing .190" double check the measurements when you take apart the transmisson... |
