Cam angle sensor question?
I have a SR20DET motor in my s13. When I start up the engine. It just tend to die. When I unplug the MAF sensor. The car stay running but when rev it run funny. Could it be the Camshaft angle sensor. How would you know if your Camshaft angle sensor is bad?
Any Info will help. thanks guys |
my car throws a code 11 , Camshaft Position Sensor , not sure if its the same or not, but i dont know how to check to see if its bad or not, but if i were you id check for boost leaks
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
guys the FSM tells you how to test your CAS also run search the FAQ and Archive on here on how to retrieve trouble codes from your ECU
I never knew you could do that with an eggplant |
![]() Join Date: Oct 2004
That is exactly what mine is doing right now. Does it throw a code 11 with the maf plug off or on? Mine was idling rough for a few secs then it turns off. Then I unplugged the maf and it ran better, but only to 2500 rpms, then it won't go past that. I got a code 11 with thte maf plug off, but a code 55 with it on. Could also be the maf that could be bad. Do you have a lot of mods? Is it the stock maf?
mine throws code 11 with the maf on....the first time i checked the codes it threw a 55 then an 11, but wheni checked it again to be sure, it just threw an 11 ...... but the car runs fine.... so maybe i shouldent worry
