Old 08-10-2010, 03:16 PM   #1
marcus8789
marcus8789 is an unknown quantity at this point
Seriously, First start up and its knocking?
I just got my s14 sr20det Kouki in the mail last week and upon first start up, there is a loud knocking sound coming from the engine. I can’t tell if it’s coming from the head or the block, so I’ve made a short video on youtube so all of you guys can see/listen to it. I Have a thirty day warranty on this engine…..so the quicker I can figure out what’s wrong and either fix it, or send it back will be greatly appreciated. Tell me anything….I’m desperate here. I feel like I got ripped off…… L
YouTube - ‪s14 Kouki sr20det loud knocking‬‎
Thanks;
Marcus
marcus8789 is offline   Reply With Quote
Old 08-10-2010, 03:17 PM   #2
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Doesnt really sound like rod knock...sounds like the head.
this is rod knock YouTube - ‪Rod knock‬‎
Loose timing chain? check the rocker arms?
StryfeS13 is offline   Reply With Quote
Old 08-10-2010, 03:20 PM   #3
marcus8789
Do you think its a lifter?
Marcus
Old 08-10-2010, 03:25 PM   #4
StryfeS13
It's Always Broken.
StryfeS13's Avatar
I'm not sure.
But it does not sound like a rod.
Get a stethoscope and start listening around the engine...
Old 08-10-2010, 03:39 PM   #5
marcus8789
[QUOTE=StryfeS13;3583072]I'm not sure.
Get a stethoscope and start listening around the engine...[QUOTE]
Looks like I'm gonna have to. I think this is garbage.....I buy a motor and rite off the bat i have to go inside and work on it. Never buy a motor from jdm_planet.
Old 08-10-2010, 03:43 PM   #6
Sam_Well.13
Sam_Well.13 is an unknown quantity at this point
def not a rod knock. seems to be could be a loose timing chain because, referring from video, its from front of the engine. Could be that, or sticking lifter. Maybe do a tune-up and add LUCAS oil stabilizer, or MARVEL OIL. You can get those at autozone, used it on my N/A SR and it slightly got quiter.
Sam_Well.13 is offline   Reply With Quote
Old 08-10-2010, 03:49 PM   #7
StryfeS13
It's Always Broken.
StryfeS13's Avatar
You know what...I had a similar sound on my KA once. Turned out to be a loose flywheel. It's a longshot, but at idle, hold in the clutch and see if it stops.
good luck
Old 08-10-2010, 04:16 PM   #8
hulkster_s13
hulkster_s13's Avatar
hulkster_s13 is an unknown quantity at this point
Sounds like my sohc when it had an exhaust leak.
hulkster_s13 is offline   Reply With Quote
Old 08-10-2010, 04:25 PM   #9
JEDIs13
JEDIs13's Avatar
Trader Rating: (31)
JEDIs13 is an unknown quantity at this point
Feedback Score: 31 reviews
good luck
I had this same problem, it made noise even with the clutch engaged tho. Wouldn't hurt to check
Originally Posted by dOMEmE View Post
mine is the "cocaine diamond" why, becasue i like cocaine and diamonds
JEDIs13 is offline   Reply With Quote
Old 08-10-2010, 04:29 PM   #10
Sam_Well.13
im having that now^^^ its a bad throw out bearing.
Old 08-10-2010, 04:33 PM   #11
marcus8789
Oh I forgot to tell you guy that the motor doesn't knock like that when its warming up. It only knocks when it reaches operating temperatures.
Old 08-10-2010, 04:42 PM   #12
icedsole
icedsole's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
VTC tick. common problem. try lifters, springs, maybe a new solenoid ect.
@pwrmves14
Old 08-10-2010, 04:44 PM   #13
marcus8789
Old 08-10-2010, 04:48 PM   #14
S14DB
AFC #1
S14DB's Avatar
Does it change when you rev the engine? Get louder or or does it go away?
Old 08-10-2010, 04:52 PM   #15
marcus8789
Good question....it actually gets a lil quieter/stays the same.
Old 08-10-2010, 05:01 PM   #16
S14DB
AFC #1
S14DB's Avatar
If it went away I would say VTC. Goes away when VTC engages off idle.
A slight decrease sounds like timing change related. Chain is rattling on something. Gets a little better when tension increases.
Old 08-10-2010, 07:47 PM   #17
marcus8789
So i took off tye oil pan and draind all the oil and there was all kinds of these little metal shavings......wtf?
http://i.imgur.com/dfdIx.jpg
Old 08-10-2010, 08:34 PM   #18
S14DB
AFC #1
S14DB's Avatar
Looks like from one of the guides.
Old 08-10-2010, 08:43 PM   #19
Sileighty_85
Sileighty_85's Avatar
sounds like the HLA's have air in them.
Bleed the lifters
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-10-2010, 08:47 PM   #20
marcus8789
Bleed the lifters
Ok.....but what about the metal shavings in the oil pan?
Old 08-10-2010, 09:02 PM   #21
Sileighty_85
thought those were scratches on the oil pan
Like S14 said might be valve guides
Its not from the bearings If it was bearings you would see brass shavings in the oil pan
Pull the front cover and check it out
後輪駆動車1番
1986 SR86 - 200ish
Old 08-10-2010, 09:05 PM   #22
marcus8789
What would you do? Fix the motor (guides, valves, etc..) or just send it back? How much do you think all that would cost me to fix?
Old 08-10-2010, 09:12 PM   #23
ballinnmiami240sx
ballinnmiami240sx's Avatar
ballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura about
easy fix dude. Call the guy you got it from and get a new motor. Dont deal with a motor that has problems from the get go. Remember that we are buying used engines from unknown sources. sometimes you can get a bad engine. I wouldnt automatically fault a company for something like this. Call them up and see what they have to say. I have gotten motors from a dude in canada and we had a bad HG from the get go and he sent us a whole new engine and let us keep the bad one. Give those guys a chance.
1994 FD3S Drift // 945garage // sumospeed.com
ballinnmiami240sx is offline   Reply With Quote
Old 08-10-2010, 09:16 PM   #24
Blkprez
Blkprez's Avatar
Blkprez is an unknown quantity at this point
damn that send that shit back!!!!~!
Blkprez is offline   Reply With Quote
Old 08-10-2010, 09:18 PM   #25
marcus8789
I've talked to the guy numerous times. He says he wants me to pull apart the engine and tell him what the problem is and he'll send me a block. He says its not the head, so he doesn't wanna ship a head to me. Then hr goes and tells me that he doesnt wanna ship me another motor bc it costs too much. The guys beginning to frustrate me. Y should I have to do all this work when hes the one that's in the wrong? Am i rite? I need a little input from someone else outside the box lol
Old 08-10-2010, 09:18 PM   #26
Sileighty_85
Id contact the Engine importer and let him know whats up.
Id ask if I could try to ID the problem by tearing the engine apart.
And if its pretty bad then id put it back together and send it back?
EDIT: damn should have refreshed before posting
後輪駆動車1番
1986 SR86 - 200ish
Old 08-10-2010, 09:43 PM   #27
ballinnmiami240sx
Well it sounds like you have no clue as to what the problem could be and this might be getting the engine supplier a little frustrated. As a small business owner my self the first priority should be to satisfy the customer. He im sure will be willing to make thing right for you as long as you can tell him what is up with the engine. i would take it to a place and have it officially diagnosed and go from here. It will save you time and money. Your 30 days are already coming to an end. A rod knock is very evident and you will have tons of metal shaving in your oil pan. Your oil will basically look like metallic paint. A lifter that needs to be bleed could also sound like this. In about 3 hours you can take the cams out and bleed the lifters. it will save you time from ripping the engine out and frustration on sending it back.
Old 08-11-2010, 08:27 AM   #28
S14DB
AFC #1
S14DB's Avatar
The timing chain guides. They are about the right length to be shavings off it.
Is he going to pay for labor too?
You are going to have to pull the motor. Then pull the head off then the front cover to see whats broken and whats worn.
Timing chain kit alone is $400. If you need all the guides too that's another $200....
Old 08-11-2010, 09:04 AM   #29
Sileighty_85
haha thats what I meant, I dont know why i said valve
後輪駆動車1番
1986 SR86 - 200ish
Old 08-11-2010, 09:11 AM   #30
4-20sx
Trader Rating: (50)
4-20sx is an unknown quantity at this point
Feedback Score: 50 reviews
Send a message via AIM to 4-20sx
SEND THAT SHIT BACK!!!!!!!!! or if you want you could also diagnose the problem, fix it, and then you gain knowledge! =)
"get that nacho out of my face"
4-20sx is offline   Reply With Quote
