Running shroud-less with GKTECH fan blade?
Hey guys I recently installed a mishimoto radiator, and my OEM fan clutch blades are cracked. Would there be any cooling issues if I run without a shroud, an aluminum rad, and purchasing the GKTECH fan? ( no shroud as Im running Nismo mounts). Also planning on gluing the cracks in my OEM fan blades with a type of very strong adhesive in the mean time( a product harder than plastic epoxy sold over here in Puerto Rico).
![]() Join Date: Jun 2003
Trader Rating: (129)
trim the shroud, also read the directions from GKTech, they clearly specify what engine/mount setups won't work
mechanical fan with no shroud is WAY less effective |
![]() Join Date: Jun 2004
Trader Rating: (73)
I have Nismo motor mounts, gktech fan, and a fan shroud. Not sure what the problem is.
