Old 01-31-2014, 12:51 AM   #1
l adam l
l adam l's Avatar
l adam l is an unknown quantity at this point
RB rb20det questions
i've done some research on my rb... itll run fine then to a certain point it will run like **** it kinda sounds like a boxer engine its misfiring so much...its the ignitor chip which i plan on changing to a j30? chip. is that the best one to use? or which one is the best? also what injectors are interchangeable with the rb20?
l adam l is offline   Reply With Quote
Old 01-31-2014, 01:03 AM   #2
Sileighty_85
Sileighty_85's Avatar
As far as RB20's go Electronically not much is really plug an play from other Engines.
You can use an RB25/Z32/J30 ignitor but have to repin and use the new ignitor plugs
same goes for the Injectors they are RB20 specific for OEM plug and play (unless it was a R32 RB25DE)
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-31-2014, 01:09 AM   #3
l adam l
l adam l's Avatar
so you could use rb25, z32, etc injectors if you were to get the harness for it to repin it?
...nvm i think you answered this already. thanks!
Old 01-31-2014, 02:31 AM   #4
l adam l
l adam l's Avatar
i plan on running e85 in the future...would 750cc injectors work? i am only wanting 400ishwhp out of this car...i know i need more than just injectors, i need some type of engine management, just seeing if anyone else has used these on e85 before? i've searched and found nothing...if someone has already answered this post a link please!
Old 02-02-2014, 12:34 PM   #5
DRD
DRD is an unknown quantity at this point
I had a what sounds like a similar misfire issue. I traced it back to poor grounding of the ignitor. Once those grounds were making a solid connection, I never had another coil pack issue, and never changed the ignitor. My old RB20 setup made 400whp on e85 at 20psi. It was super fun, but extremely laggy. I do not recommend running the same T04E turbo. At that hp/boost level I was maxxing out my walbro 255lph fuel pump. I ran 1000cc modified KA24E injectors, as these were a direct bolt in to the stock fuel rail. High impedance/top feed. For an ecu I ran Apex'i Power FC that was modded for an RB20.
dyno:
engine:
in car video:
e85incar.wmv - YouTube
DRD is offline   Reply With Quote
Old 02-02-2014, 12:47 PM   #6
DRD
sorry, just going to dump this here for anyone searching in the future, as I remember it took me forever to find:
RB20DET base ignition map:
and RB20DET ecu pin out diagram
Old 04-04-2014, 02:01 AM   #7
l adam l
l adam l's Avatar
bad grounding on ignitor? just ran grounds to something else or rewired them and back in same spot?
Old 04-16-2014, 12:03 PM   #8
Con-city_s13
Con-city_s13's Avatar
Con-city_s13 is an unknown quantity at this point
KA24E injectors are identical to stock rb20 injectors.
I have one on my rb20.
Con-city_s13 is offline   Reply With Quote
Old 04-17-2014, 12:54 AM   #9
l adam l
l adam l's Avatar
That's a good tip. Thanks
Sent from my SAMSUNG-SGH-I337 using Tapatalk
S13 is a sporty garbage can.
