S13 with s14sr20det (need help with vac lines an bov vac)
im having trouble with my vamcume lines..
i have 4 nipples under my intake manifold. two that poke out further and two small ones. what goes to what? i have a boost guage im hooking up and boost control.. click on my thread underneath! S14 sr20det in s13 not running so good |
![]() Join Date: Apr 2008
Trader Rating: (18)
Too many threads about this exact same thing to count.
Did you even bother searching??
WTB: S13 Silvia front pieces Need: Hood, Fenders, Bumper, Headlights + brackets. Have decent pop-up front to trade with oem hood + vis racing carbon fiber hood if interested. |
The two under the manifold are boost/vac sources. The ones on your throttle body are boost only sources. You should have one that sticks out on the right side of the upper manifold for the FPR. It's hard to tell you what those lines should go to because everyone's setup is different. Wastegate needs boost only, charcoal canister needs vac, fuel pressure/boost/bov's need to see pressure differential, I.e. boost and vac. What external vac/boost systems are you running?
My SR20VET |
