| Forum Suggestions & Technical Support Post any suggestions or questions related to this site. |
![]() Join Date: Nov 2004
For one, you should have either posted this in the Technical section. And secondly, yes you can. Scroll to the bottom of this link. #/f/payments.html
#4 | |
![]() Join Date: May 2009
Next time please post correct info and don't just assume.
![]() Join Date: Jul 2007
Moved to correct section. Also, you're not having an 'issue' with your user name (ex. your profile going to someone else's), you just want to change it. There's nothing wrong with it. |
Honestly what does it matter? This site has way to many people that are always just trying to correct people. Thank you for answering and thank you for putting it in the correct place but come on people... Yall act like it the difference between life and death if someone gets something wrong on here. Do I need to read a book on how and where to post on here?
Drifting isn't a Sport... It's a way of Life! |
Read the stickies a the top of most sections. It will make life a lot simpler for you when it comes to this website.
#9 | |
![]() Join Date: Sep 2002
The other subscriptions have defined time limits, whereas name changes don't, so it says "one day," but the change is permanent.
