By entire rear end do you mean diff, hubs and axles?
USDM S13 and S14 are R200's with 29-Spline output shafts, 6-Bolt axle cups (3 pairs of 2 bolts in a "Y" shape) most were 4.08:1 ratio.
USDM Z32 NA are R200's with 29-Spline output shafts, 5-bolt axle cups, 4.08:1 ratio.
USDM Z32 TT are R230's with 30-Spline output shafts, 6-bolt axle cups (the 6 bolts are evenly spaced in a star), and 3.69:1 ratio
USDM G50 (Infiniti Q45) are R200's with 30-Spline outpus shafts, 6-bolt axle cups (the 6 bolts are evenly spaced in a star), and 3.54:1 ratio
JDM R32 and R33 are R200's with 30-Spline outpus shafts, 6-bolt axle cups (the 6 bolts are evenly spaced in a star), and 4.08:1 ratio
Copied and pasted. There's a possibility of that being inaccurate.
