s14 driveshaft length?
So I swapped an s13 sr20det into my e30 and modded the rear diff to fit the nissan u joint setup. I am trying to figure out if there is an off the shelf driveshaft I can make fit rather than going 100% custom.
I have an s13 shaft that measures around 47 and 1/4 end to end. I need one where the slip yoke starts around 49ish inches. So obviously both s13 abs and non abs are too short. Unfortunately I cant find any definite answers on how long s14 shafts are. Any help is greatly appreciated. ![]() The only info I have been able to find on s14 shafts is this picture and its a bit too long so im hoping there is maybe a slightly shorter one? |
Ive also seen this info but the numbers don't add up to me based on the actual s13 drive shaft I have on hand. The only thing that makes me optimistic is that the s14 one is clearly longer based on these numbers.
S13: Section 1: Coming From Trans (ABS makes no Diff. in Length here) M/T = 395.0mm (15.55") Section 2: Center Bearing/Mount to Diff Non-ABS = 605.0mm (23.82") ABS = 590.0mm (23.23") S14: Section 1: Coming From Trans (ABS makes no Diff. in Length here) M/T = 421.0mm (16.57") Section 2: Center Bearing/Mount to Diff Non-ABS = 650.0mm (25.59") ABS = 636.0mm (25.04") |
