Import Revival - Featured Product - Tomei 2-Way LSD
Import Revival - Tomei 2-Way LSD - 550.00 Shipped. 5-Bolt Output shaft and Axles available. PM for details. Description below.
Welcome to Import Revival Inspected OEM and Aftermarket Japan-Specific Used Parts and Accessories Import Revival is committed to providing fellow Zilvia Members with hand-picked, Silvia, SR20DET, 180SX, and Skyline-related used, and sometimes new, parts and accessories, in an effort to assist fellow enthusiasts in maintaining reliability, and performance for your Japan-Spec powered, or modified projects. Having a healthy selection of local Importers from whom to choose various, interdependent Silvia, 180SX, and Skyline-related parts, for your selection, Import Revival is not limited by a restricted variation of parts thrown in a container - so very few times a year - that all that one is left to rely on, is the often detrimental consequence of that fact. Each and every Engine, Long Block, part, and accessory is handpicked personally, with diligence, and care taken to insure an adequate and legitimate condition of each available item, for members of the Zilvia community. Keep in mind, of course, that these parts, unless otherwise specified, are used, and normal wear and tear is expected. What I do guarantee, is that each items is described as accurately as possible. Description: This Tomei Limited-Slip Differential is imported from Japan. The unit is as you see depicted, the oil was very clean when removed. This differential, is of course used, and is in very good condition. |
