![]() Join Date: Feb 2012
need Offset and Tire help with coils..
Ok so on monday i picked up a 89 hatch shell with a 95 KA24DE and only 71k on it for $450. (Spare block for KA-T build)
The guy had already sold the tranny so i got it cheap. Found out it had 180sx seats in it so i swapped those into my coupe. When i went to pick it up i found it had aftermarket wheels.. but there is no brand name or anything on them so im guessing they are a cheap pep boy wheels or some crap. The wheels are 16's umm i would guess 7.5'' or 8'' width with Nitto 225/50/16's all around Now my car is dropped on coils and i test fit the fronts and im scared they will rub. (There is maybe like 1mm of space) Anybody got any idea of what kind of spacers i should run if any? And who the hell makes these wheels????
"I have no cupholder" |
![]() Join Date: Sep 2006
sounds like u almost answered your own question. get a 5mm and you should be good
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
^ was gonna suggest 3 but wasnt sure they made em lolz
![]() well can anyone identify these wheels?
yeah man, i aired on the side of caution when i mentioned 5mm, because a little more clearance is always better. sure you have 1mm of clearance now, but once youre driving, things like hard braking and accelerating, as well as turns especially in inclines/declines will put more weight on your tires, making them bulge out a little more and possibly rub. but you dont want to run too large of a slip on spacer cuz itll push your wheel too far from the hub.
