Have been having troubles with the clutch sticking to the floor, replaced the master, slave and the line from the master to slave was replaced with a chase bays one . Just greased the spring under the pedal and still after about 5-10 minutes of driving the clutch with start sticking to the floor again. When the car isn't driving and just at a stand still it won't stick, only after a few minutes of driving I'll go shift and it will stick. any help will be greatly appreciated .
![]() Join Date: Feb 2012
Trader Rating: (37)
Sounds like you're boiling your fluid in the line somewheres. Does your brake peddle feel a lot softer when you're experiencing this issue w/ the clutch?
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
I didn't notice anything while it happened, I was driving after replacing the mast and slave, and the line from the master to the slave. Drove good for about 5 minutes and it started sticking, then shortly after stuck right to the floor. Had to brake and pull over and I didn't notice the breaks, but I also wasn't paying much attention to.
Trader Rating: (37)
With the car off, will it stick to the floor after pumping it a couple of times or whatnot?
