s13 digital climate control issues
hey guys i just installed my jdm digital climate control the other and everything works great except a few things....at certain times when i start my car my a/c would come on and blow at max when the unit is off....and also when i reverse it blows also....if anyone has a fix for this that would be great......also im in need of a door blend actuator ......so if anyone has that then that would be awesome too...
I had this exact problem. It was a short, I can't remember the part name, thermo control amp or something. Its behind the glove box held on by 2 hex head screws. When I loosened it the problem went away. So I pulled it out and could see it touching an aluminum pipe in the airbox. Gentlely push that pipe away and it should work properly.
