![]() Join Date: Nov 2011
Got a bunch of 240 stuff laying around I need to get rid of. Lmk what you need, ill ship items if your willing to pay for shipping. Located in Philadelphia, PA.
Edit: Sorry for big pics didn't realize they were huge. $50 each, slight wear on the se wheel, other wheel is mint. ![]() ![]() $50 take it all, s14 intake manifold with a bunch of accessories. ![]() $70 for it all. Ac, bracket, and line. ![]() $20 fuel rail came off s14 ka $5 master cylinder ![]() $40 Oem clutch good condition $5 s13 distributor (throws a cas code needs repair) $10 License plate lights $5 Exhaust hanger $20 stock intake manifold with filter. ![]() $10 each s13 exhaust manfiold ![]() $10 Cruise Control Cables $10 heat shield $10 s14 obd2 throttle body $10 Iacv Unit $10 Egr tube/unit $10 Ac condensor ![]() $40 s13 struts. Have two rear and one front. ![]() Anything you need from this pic. $100 Come get the whole motor or buy parts. I believe it has a rod knock. Started ticking which got progressively louder so i turned it off. Towed the car home and instead of ripping apart the motor as planned, I just bought a new one and swapped. $40 Valve Cover $20 Valve Cover bolts $40 Ac $40 Power steering $50 S13 Cams ![]() ![]() ![]() Last edited by DennisS; 07-01-2015 at 06:45 PM.. |
