![]() Join Date: Mar 2011
Trader Rating: (50)
![]() Feedback Score: 50 reviews
HKS GT2540r, S14 SR20 Greddy style Intake, Daft sway Spacers, More
Shippin available at buyers expense + paypal fees. Unless stated.
Price reduced....... [B]I will only TRADE for: Z32 diff cover, Vertex or Cwest Wing, S14 fender brace, S14 Cf trunk, Cf Hood w Scoop, Defi Din Gauges kouki cf cooling panel, S14 Sr20 Vtc, --------------------- HKS Gt2540r (Great Shape) 795 No shaft play if any. Ran on my sr for Very short while. Comes with HKS Actuator, HKS Oil Line (Restrictor specific) & New Oem Oil Return Hose. Direct Drop in for sr20's. Very similar to the 2871 turbo. ----------------- Link: HKS Turbos - HKS GT2540R Turbo HKS GT2540R - 360/370 PS Output COMPRESSOR: -Wheel- 46 Trim - 51.7 Inducer / 76.2 Major -Housing- 60 Inlet / 50 Outlet - 0.50 A/R TURBINE: -Wheel- 76 Trim - 53.8 Major / 47.0 Exducer -Housing- GT25 inlet / Internal GT25 oulet - 0.64 S14 SR20 Greddy style Intake w IACV (Missing the idle screw)- 130 S14 Daft Swaybar Spacers (For Ls1 Swaps, might work w RB)- 50 shipped S14 OEM Tie Rods (Great Shape, 35,000 miles)- SOLD S14 PS Resevoir & hose with ps Aluminum Hardline- 45 [URL=http://s880.photobucket.com/user/beno842/media/Mobile%20Uploads/image_zps1e2cdf50.jpg.html][IMG]http://i880.photobucket.com/albums/ac2/beno842/Mobile%20Uploads/image_zps1e2cdf50.jpg[/ S14 Sr20 Oem oil sender block (No sensor)- 40 OEM S14 Fuel pump, Works Great. Swapped for Walbro (Lil nicked on the bottom)-30 S14 lower brace Oem brackets- 40 S14 4 LUG HUBS (4x)=50 S14 BALLER BOLTS Fr Strut bolts- 25 shipped S14 Dr Hinges- 25 shipped FR. S14 brake calipers and lines (NO ROTORS)-40 [B]S14 Hood prop-SOLD Oem S14 Radiator panels (Don't know exact name)-22 shipped S14 tension rods-15 S14 RHD ABS unit & abs lines- 90 S14 rhd jdm A/C High side line-10 RHD S14 air ducts (Under dash)-7 each JDM s14 condensor-30 S14 Battery/Ground wire- 7 each S14 oem Slave Damper, Slave Cyl, RHD Clutch line- 60 SR20 Clutch ( came off S14 SR, Low mileage)- 40 S14 Dust Sheilds- 7 each Last edited by Relentless240; 09-16-2014 at 07:48 PM.. |
