S13/KA Garage Sale
I need this stuff gone from here and out of my garage. I will work with the price and shipping on most of this stuff. PM is the best way to get a hold of me. So here we go:
KA24DE T3/T4 turbo manifold $old Steering wheel $old Manual Transmission crossmember and mount $old Manual side mirror, passenger side, no mirror (easy replacement) $5 S13 valve cover $old S14 distributor and pigtail $40 KA24 ACT six puck clutch disc (unsprung) roughly 3k miles on it $75 Same disc as here KA24 clutch kit six puck sprung NA applications less than 5k miles on it $old S13 KA speedometer sensor, tested works $old S13 door lock timer $5 S13 power door wiring $10 S13 seat belt controller $5 KA24E ignition coil $20 Z32 30mm aluminum calipers $old DOHC powersteering reservoir and steering rack lines (with high pressure hose) $old S13 power mirrors $20 each Passenger side $old Coupe tail light housings $25 each pair with bulbs $15 without. 1 PAIR $old S13 sun visors $5 pair KA24 A/C compressor (condition unknown) $30 Power window regulators and motors (working when removed for manual windowed track car) $25; drivers side sold Steering wheel $old S13 SOHC throttle cable $old S13 toe arms (bushings still good) $15 both S13 traction arms (bushings good) $15 both KA24DE fuel rail $10 S13 non-ABS master cylinder (7/8" worked great) $15 S13 koni housings (save time hacking up yours, for ground control/custom coil over setup) $old S14 housings (used with ground control setup, and Bilstein damper, weld ring already in place above the tire) $30 Last edited by Ruff Ryder 6; 03-06-2011 at 12:41 PM.. Reason: sold stuff |
i need the driver power window regulator and if possible 1 ka injector pm me on shipping plz?
4MationD! 90se RB26:build,95pgt KLZE swap:daily,92le vh45 swap planned
#18 | |
460
| caliper, clutch, manual, steering wheel, turbo manifold |
