![]() Join Date: Feb 2008
![]() ![]() ![]() Feedback Score: 6 reviews
so i have a s13 black top sr20det (non type x motor).. i did some reaserach here and on a few other websites and came up empty handed..
so my question is were and how do u check valve clearance from and under what condition (cold engine warm engine ect ect) and what is spec.? any input would be helpfull |
![]() Join Date: Mar 2006
That's a tough one....the only FSM that I know of or have seen (in English) is for an S14SR....
I'm sure one of the experts on here knows that....which clearance are you referring to though? Clearance between cam and rocker arm?
![]() Daily driven |
^^^ yea im not sure if its 100% the same specs you know so im kinda ify but i a, refering to the clearance between the cam and the rocker and the rocker to the valve if their is a measurment for that one.. basically im trying to find the root of my tick tick noise.. which i think is the the lifters not being bleed properly or the valve adjustment is out of spec..
![]() Join Date: May 2005
I am not sure about the Rocker to Lobe clearance, but for Valve to Rocker (Shim) you need a shim height tool.
Only place I know is RPSport Oh.. did you bleed your Hydraulic Lash Adjusters? |
There was a link, i think it was on ziptied, a guy made a tool that works just like that one for like 30 bucks, using harbor freight stuff, someone help me out.
#9 | |
Man w/ CTSV & a Car Seat
It would make ticking noises...try bleeding all of them first. Take each lifters off, submerge it in oil and stick something in the hole to force the bubbles out.
Yeah like everyone said it sounds like a ticking coming from the head....
You need to pull the HLAs and stick something thin in the top and push it up and down quickly to get the air bubbles out. ..oh yeah and this should be done while the HLA is submerged in oil....once you finish, keep it upright.
hmm yea thats what it seeems like do u know if their is a DIY anywere .. i know jgy shows what to do but its not very clear .. if theirs any one that can help let me know.. plz
all efforts are greatly appericated |
DIY for what? Bleeding the lifters? If you aren't experienced, I wouldn't mess with this.
It involves pulling the valve cover, cams, etc Then there is the possibility you tq something the wrong way, mess up your time, lose a shim, etc. Are you sure you wanna do it yourself? If you can do it, go for it, but stuff CAN get messed up in there if you don't really know what you are doing.
![]() Join Date: Sep 2007
Funny story, i just made a write up for the reshimming the valves and stuff.
Another thing you might want to check for is your HLA's. Take them out and re-bleed them, these type of HLA's cannot be bled by running the motor. What you do is take them out submerge them in oil take a little metal rod and put it inside and find the little relief ball thing, keep pushing it down until all the air is out. Have fun with your new quiet SR. Hope this helped. Oh, and here is that write-up/ How-To SR Valve Shimming. - Page 2 - Socal-Drift
#16 | |
#17 |
I think he wants pictures because he doesn't know what he's doing. You've been here almost two years and don't know how to search? The guy gave you information steps how to do it. We can't spoonfeed you all the time.
You have not searched because "bleed lifters sr20det" comes up with a step by step article with pictures on the first hit on google |
#18 | |
im sorry my search wasnt the same as yours but i did search but i searched another item as for giving me shit for it not cool man .. if i would of known i was gonna get flamed i would of not asked the question.. as for all the other people helping me thank you alot .. ive found the problem and now i know how to fix it.. |
