what wheels fit an s13
i was just wondering what other makes and models make wheels with the same lug pattern as the s13 (4x114.3)
i gotta find out what other rims i can throw on my car because i cant even keep up with all the tires im going through |
![]() Join Date: Feb 2006
Trader Rating: (47)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 47 reviews
Your initial question is kinda weird.
So you want to know what other car makes and models have the same wheel pcd so that you can buy them to use the tires? But your thinking that the wheels you have now are making you go through tires too fast? Or is it that you want extra wheels to put tires on for the track? I don't think its your wheels. Check your alignment. It could be off and thus causing fast tire wear. Are you drifting also? Hopefully that's the answer your looking for. The wheel doesn't make your tire wear fast. Also you could just buy new tires. |
#8 | |
![]() Join Date: Feb 2004
'93-'01 Altima '85-'88 Maxima '84-'88 200SX '90-'97 Accord EX/LX/Wagon '92-'96 Prelude Si I figured there'd be more Fallbrook guys getting on Zilvia. It was only a matter of time. |
you're not going to find any oem 4x114.3 wheels that are going to look/fit good on your s13. apart from maybe some 280zx wheels, but the best looking of which are 14in diameter.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
bushido idk if you know what ur talking about, plenty of rims look good...like the stock sentra ser rims but i havnt been able to figure out what years exactly (i no they are relatively early models like 00'), ive seen ppl do it and they look great but im not gonna search around for rims for u man srry. it is pretty easy to figure it out if you look in the right place.
96 240 w/ sr |
#11 | |
