Hey everyone got a huge GT wing up for grabs, YOU WILL BE GETTING A BRAND NEW as I have purchased more then 1 initially. Offering a quality affordable GT wing solution that is tall and wide perfect for S-Chassis owners. Similar to Origin, the wing is massive! Specs: -Fully Adjustable! -69' wing tip to wingtip -10.5' wing deck length -17' tall wing stand (just the stand at highest setting add 1 inch for wing addition) outer to outer bracket widest point 34' -Wing Material: Full Carbon Fiber Microweave -Wing end plates: Full Carbon Fiber Microweave -Stand Material: Full PFRP hardened stand and brackets **new stands aluminum now!!!** -Hardware: All included grade 6 hex bolts and nylon lock nuts with washers -Brand: AWT manufacture same as ORIGIN -Fits: S14 trunk,S13 Coupe Trunk, RPS13 hatch no problems! -Top of the sits almost even with roof line (if not just a tad bit higher, but wing is fully adjustable). Price is: $385.00 picked up in So Cal Shipped anywhere in lower 48 states: $440.00 *shipping prices a little more expensive due to oversized item Located in Orange County: La Habra, CA 90631 Thanks guys!
I'll take the stands. if TheRealSy90 takes the wing
#20 |
i met him today to get the GT wing.
he is a trustful business man. he unwrapped the wing carefully and showed me all the hardware. i hope to make business with him again. |
#21 |
Thank you! I hope the wing does you well when your back in Germany!
| 240sx, aerokit, gt wing, huge, origin |
