![]() Join Date: Jun 2007
engine...
Z32 maf w/ harness - 125 shipped never used Love fab top mount manifold- 850 (cost 1800 )Apexi power Fc Ljetro (maf) - 825 Fidanza Flywheel- 270 shipped Exedy stage 2 clutch kit - 250 shipped sr20 BARE head - 200 shipped Nismo thermostat- 30 rocker arm assembly with all hardware etc- 70 shipped pretty much new apexi filter for z32 maf- 80 shipped Almost new B&M short shifter- 175 shipped Almost new Nismo black but plug shit nob - 30 shipped Used apexi metal head gasket... still in good shape.. layers dont stick to eachother, will work fine again- 70 shipped Valve cover- 60 shipped with NEW gasket New HKS ver 2 on hot pipe - 220 Greddy spec M fmic KIT- 300 Greddy oil pan- 280 Silvia Radiator- 130 shipped.. comes with Fal fans and all wiring.. one of the fans is kinda wobbly tho... PS pump with bracket and belt- 100 shipped Water pump- 50 shipped Ignitor chip- 80 shipped COMPLETE s13 red top engine harness- 200 shipped .. CLEAN harness oem tranny harness ready for sr20- 60 shipped.. comes with speed sensor Trust DP- 100 shipped Nismo tranny and motor mounts- 160 shipped sr20det tranny- 220... no shifter or slave cylinder Sr20 complete block... weak compression- 400 altenator- 80 with bracket oem fuel rail - 70 shipped suspension- Tein flex coilovers with approximatly 6k miles on them..never tracked- 1050 Megan tension rods-80 shipped Megan racing rear traction links-75 shipped Philipps FULL HID kit.. 8000k... really nice kit- 250 shipped.. thats half off.. comes with metal tabs to fit the mounts in the head lights.. 180 sx calipers/ cross drilled altima disk brakes/JDM brake booster/oem master cylinder- 280 sparco pedal kit - 45 shipped.. made of aluminum head... tein coilovers.. one of the studs up front is shorter then the rest but still as plenty of bite on the nut so no worries there Last edited by ((sr)) kelly; 10-23-2008 at 10:35 AM.. |
Here are some more pics...
full engine harness tranny harness for 5speed... sr ready pics of the 180sx calipers.. Megan racing tension rods and rear traction links.. Nismo engine mounts.. i have the tranny mount too IACV Last edited by ((sr)) kelly; 10-02-2008 at 08:05 PM.. |
![]() Join Date: Jan 2008
Location: Amerika24 alabama: Where if your not first..... your last
i want short shifter bad but monies is very tight right now and i just paid my tuition
whats the lowest you can go? I dont like lowballin you but i was just wondering
#26 |
Want to part with the rear main seal plate, bolts and all upper oil pan bolts?
My SR20VET |
#30 |
I am interested in the FMIC kit and the hot pipe with the HKS SSQV if you are willing to ship to 20164. Please email me at [email protected]. thanks.
