S13 coilover question!!?? WTF
Da fuq?
Is the threaded portion on them different lengths (as in the male threaded part). or is the bracket different(female threaded portion)
@UpshiftEngineering |
#4 | |
![]() Join Date: May 2009
So how are you measuring ride height? If you are measuring it off the frame/body those brackets are going to be in different spots depending on how tweaked your car is. That upper measurement on the spring is only to set preload and should be the same on both sides.
dont the thread space between the collars suppose to be the same giving you same height right and left
I will give you my pistol ammo at the speed of light towards your doom
Based on the pictures it depends on how you are measuring ride height as stated.
Either your frame is tweaked or on side of your car is sitting and inch higher than the other. The portions that measure the same on both side are just preload, dont mess with this or preload your coils. |
#10 | ||
Fast, check all your arms and such, hopefully the issue is contained to that or your crossmember if something really is tweaked.
![]() Join Date: Aug 2011
There is a jacking effect involved if you turn the wheels, keep them straight and measure again.
And disconnect your ARBs when setting the ride height, or you WILL preload them. |
#20 | |
It depends on what Stance has as standard, it could be snug or it could be snug then tighten down 3mm, 5mm etc. You can contact them to get this info if its not available online somewhere. As for the tweaked parts I would start looking at your crossmember and all the replaceable parts to see if anything is bent, if you are lucky that is where your damage is contained.
