![]() Join Date: Nov 2008
Trader Rating: (31)
![]() Feedback Score: 31 reviews
![]() 89 s13 stock sohc automatic
My car started acting up last week, it wouldn't start unless I put pressure on the shifter pushing it towards park. I would turn the key and nothing would happen at all, if i turn the key then put pressure it would start. this morning it wouldn't start at all. I have power, my windows roll down and the radio works. I took apart the shifter and the pin is pushing the parking sensor back, but I noticed the white box to the right of the shifter gets really hot. I'm going to get a shifter from pick a part tomorrow, but I was just curious if anyone had a similar problem? Is there something else I should check? I did use the search button and didnt see any threads with a similar issue |
![]() Join Date: Oct 2008
it's the neutral safety, it's to prevent you from starting the car in reverse or in a forward gear... it's probably something in the mechanical portion if it works when you apply pressure, it's possible it bent and is now broken after applying extra pressure
My 96 S14 | 501whp SOLD |
#6 | |
Trader Rating: (31)
According to projectRDM there is no neutral safety switch?
![]() Join Date: Dec 2009
Yup you should be able to start any auto car in neutral or park so long as your switch isn't busted like the one in this thread. I do it all the time in my auto. of course I've seen the sensor when it's in park be bad but work in neutral
