![]() Join Date: Aug 2011
![]() Feedback Score: 21 reviews
Racelogic GPS Data Logging & Drift Box
We've introduced these data logging units to our drag racing and time attack customers, and thought there might some Zilvians who are interested in units for as low as $430
Be sure to click the links provided below to see all available prices & options! Racelogic Drift Box CLICK HERE TO BUY! DriftBox is the first vehicle performance meter with the ability to measure drift angle. A 10Hz GPS engine, coupled with sophisticated motion sensors allow you to record vehicle performance characteristics such as drift angle, g-force, speed, distance, lap & split times and acceleration. The new Predictive Lap Timing function gives you instant driver feedback and helps you to find valuable improvements in your times. All parameters are logged to an SD memory card ten times per second for later review and comparison. The Drift box's operations are split up into the following 7 modes: Package 1 Contents Include:
Package 2 Contents all of package 1 and also:
Racelogic Performance Box CLICK HERE TO BUY! Racelogic's Performance Box is a GPS based performance meter that allows you to measure G-forces, speed, lap & split times, 0-60, 0-100, braking distance and many more. The new Predictive Lap Timing function (live comparison to best lap) gives you instant feedback on your driving and helps you to find valuable improvements in your times. All parameters are logged to an SD memory card ten times per second for later review and comparison. PerformanceBox contains an integrated antenna, is compact in size and very easy to install. The operation is split up into the following 6 modes: PerformanceBox is available in three versions. There are no differences in functionality between the three, only in which peripherals are included: PerformanceBox1 contains:
PerformanceBox2 includes contents of package 1 plus:
PerformanceBox3 includes contents of packages 1 & 2 plus:
Racelogic Vbox Sport CLICK HERE TO BUY! The VBOX Sport will allow you to instantly analyse your driving performance, giving you immediate access to the data you need to go faster. Between six and eight hours of battery life will cater to most sporting events; and because the VBOX Sport is weighs less than 200g, there will be no weight penalty for using it. The VBOX Sport can be used with any type of vehicle: Car, Motorbike, Bicycle, Jet-Ski, Powerboat etc, and you will be able to log accurate GPS data (E.g. speed, acceleration, distance, time) directly to the supplied SD card, allowing you to improve your performance using our analysis software – Circuit Tools. The VBOX Sport is officially certified by Apple and connects to iPhone™, iPod Touch™, or iPad™ via a Bluetooth connection, enhancing the GPS reception on iOS devices, or adding GPS functionality to those which don’t have it already. Features:
Kit Includes:
